    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Wires from front door broken
    Im wondering if anyone can tell me the easiest way of removing the rubber so that i can fix the break in the wires
    I can feel someone has crimped them together and one has come loose (door been off at some point?)
    My door does not lock on the remote now and interior light stays on
    My plan to get in an solder them all with a little extra wire
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,997
    Remove the rubber ducting?
    You'd have to unplug all the door cables from the kick panel near the floor (If the B6 keeps them in the same place as the B5), route them up the A piller and out through the hole near the door and out of the rubber.
    I'd pull the ends of the cable out in to the door and the other end in to the car. solder in a longer bit of cable on 1 end, route it through the rubber and then solder the other end where you have more room.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Oct 2009
    Hull
    1,440
    No need to remove it
    I would take the door card off and unclip the wire and it will give you more then enough slack
    Blackie's Avatar
    Feb 2004
    In a house
    634
    I managed to fix it in situ. Just by pulling the rubber back and tie wrapping it so it didn't keep wanting to close. Then soldered and shrink wrapped the cables.
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Thanks all for the feedback
    Not had chance to attack it yet though... Where does time go?
  1. Rear Footwell Lights/Door Trim/Carpet Removal - Routing Wires
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2012, 16:32
  2. broken door wires
    By John_ in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st March 2011, 12:57
  3. Broken wires in drivers door wiring loom
    By cnpaterson in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2010, 17:49
  4. Broken wires in drivers door wiring loom
    By cnpaterson in forum In-Car Entertainment
    Last Post: 14th September 2010, 22:08
  5. front brake pad wear-indicator wires!
    By imported_tractorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2005, 09:55
