Sky InsuranceAH Fabrications
Results 1 to 13 of 13
    Jun 2009
    Co.Cork, Ireland
    20
    Unhappy I broke my car. :(
    Had a day off today so did Mr.Muscle turbo cleaning. All went ok as per the guide on this forum until I was taking it for a spin afterwards. Was driving along ok, there was plenty of power in the car. Got to about 80mph in 5th and the engine management light came on. Pulled in, turned the car off and back on. Engine management light stayed on. Went for a spin again and there was no power in 3rd, 4th or 5th. Struggled to get to 70. Eventually managed to get to 75mph.
    Tried to disconnect the battery to clear the light but it made no difference. Any ideas?
    Edit: Meant to add 2003 B6 1.9 TDI 130bhp
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    recheck the connections on ait pipes
    and if you can scan it for fault codes
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    You really need VCDS to tell you what the fault is. Anything else is pure speculation. It sounds like it's currently in limp mode. People may say it will be this that and the other linked to your work on the turbo, and that may well be the case, however it equally could have nothing to do with the work you've just done and be purely co-incidental. Just check everything is plugged back in/re-connected properly. Once you've had it scanned, put the results up on here and it should become quite apparent whats happened.
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    Jun 2009
    Co.Cork, Ireland
    20
    Thanks for the replies. Don't have anything to do a scan with. Checked anything i took off and all seems tightly put back together. The connection to the MAF sensor does seem a bit loose though.
    If the problem rectifies itself will the light go off on it's own or can codes only be cleared manually?
    I've it booked in for a service on Monday anyway so hopefully they'll be able to sort it. Just have to keep the wife out of the car for the weekend now. She'll kill me for messing with something that wasn't broken! I'm always at it.
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Quote Originally Posted by neddynasty View Post
    The Truth there buddy.
    AUDI A4 190T S-LINE.
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Mine did this...
    Turned out one of the vacum pipes had pulled loose when i moved things out of the way
    Check around all the pipes/wires around the drivers side and front of the engine to see if youve done the same
    (just because you didnt touch it on purpose doesnt mean you didnt )
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    Jun 2009
    Co.Cork, Ireland
    20
    Quote Originally Posted by scottshere View Post
    Mine did this...
    Hopefully you're right. It's a definite possibility. I did see something that looks a bit out of place.
    It's about an inch in diameter and looks like a plastic needle sticking out of it. It's all oily too. Looks like it should be plugged in some where.
    Would this affect braking at all?
    I notice now at really low speeds (i.e. < 5 mph) in traffic the brake pedal is rock hard and takes a bit of effort to loosen it.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    looks like a pipe has come off there. have a hunt for a rubber tube possibly covered in a weave.
    Oct 2009
    Hull
    1,442
    yes
    the pipe runs to the vacuum pump at the back of the engine if you look at the pipe on the left of the vac pump it has a tee that comes off and a pipe should run from their to that one way valve
    Jun 2009
    Co.Cork, Ireland
    20
    Thanks everyone for the advice! Got it sorted tonight. Car pulling great again.
    Engine management light is still on. Can that be reset someway or if it a vag-com job?
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    that looks like a one way filter of some sort ?
    S3 GAZ's Avatar
    Dec 2006
    East Ayrshire Scotland
    347
    I knocked a pipe off the same as yourself. After i reconnected it the engine management light went off by itself after about 10mims of driving.
    Jun 2009
    Co.Cork, Ireland
    20
    Quote Originally Posted by S3 GAZ View Post
    The light went off by itself last night. Also ordered a new air & pollen filter last night. Oil and filter change has been done so once I get the air & pollen filter in it'll be happy days once again!
    Thanks to everyone for the advice. It's been invaluable and certainly calmed the nerves when I thought I'd wrecked my car.
  1. Car broke down this morning......:(
    By Gooner in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st February 2010, 21:24
  2. Ive broke my own car!
    By tedster in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th November 2009, 12:29
  3. Car broke :( KNew it would happen after saying how good it was
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd September 2009, 21:38
  4. SOME LITTLE FECKERS JUST BROKE INTO MY CAR!
    By ALPINE in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2008, 22:00
