After replacing my ecu box and seals and cleaning all plugs etc etc thoroughly I appear to have solved my previous issues, which were glow plug light flashing and no accellerator.
Now I have another problem in that every once in a while, when im driving the car will just suddenly lose all power but only for a split second before carrying on as normal. The best way to describe this, is if youve ever blipped the brake pedal with your left foot while accellerating with your right the car will instantly stop accellerating and hence give you a slight jolt.
This is exactly the same sort of feeling which makes me wonder if its a brake realted problem, however I have no warning lights come on when it happens and when i scanned the car with diagnostics a few weeks back nothing came up except the codes for my previous problem, and also a code for worn engine mount.
Maybe the engine mount could cause this problem, as it tends to happen mostly when turning right at a junction or on a roundabout.
I hope that all makes sense,
if any one has any ideas or suggestions they would be much appreciated
Steve
Steve
