Results 1 to 14 of 14
    May 2011
    136
    Fed up with the avant !
    I'm starting to really lose interest in my car ! Everything seems to be going wrong at once !
    A while ago an LED sidelight bulb melted and ruined the lamp holder ,
    My brake pad warning light has come on (looks like rears) also need to replace the discs.
    Now my service indicator is on, looks like it needs a major one plus haldex and brake fluid .
    The rear PDC has started playing up (select reverse and its a long loud beep) and doesn't warn when you get close to things.
    Drivers side brake light works now and again , so randomly get the bulb out warning .
    Slow wiper syndrome (planning on doing this when weather gets a bit better, they're that bad they quite often stop , i've been using alot of WD40 on them,
    And that leads to my next problem. Went out to do my bi-weekly WD40 spray and the bloody bonnet won't open !!!!
    Pointless thread i know so I apologise, just totally fed up !!
    Aug 2010
    1,540
    welcome to audi ownership. being forced to live with warning lights, rough running and things hanging off that shouldnt be.
    haldex? a4s dont have the novelty 4x4 system like a3/s3, it is actually 4wd!
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    We all have days like this!
    The wiper fix is an easy one, just needs a spare hour or two - have you seen my DIY guide in the sticky thread?
    I don't think there are pad wear indicators on the rear pads are there?
    Diff's are sealed for life generally, while you 'can' change it there's no requirement as such to do so, and I'm sure brake fluid will wait a bit if money's tight.
    The PDC is probably a sensor, they're not too expensive but you have to paint them. A VCDS scan will pinpoint the problem.
    4NT
    4NT's Avatar
    Terminal Douche Bag!
    York
    369
    Stubie. Sunday nights suck ass don't they. Cars whilst lovely to own can get you down huh.
    One job at a time, essential bit's first. Chin up.
    A4 B6 Avant 130 Sport Dolphin Grey. FCA - Storage Pack - Advanced Lighting - Retro Fit Cobra Park assist - Gen OEM RS6's - Parrot Kit with screen in ashtray. Coming soon, stealth audio upgrade, LCR splitter.
    Previously 60 plate Octavia VRS, Dull Mk6 Golf, A3 8P Sport with mods, New shape Jetta,2 x Passat B6 Sports with AMG 19's, A4 DTM, A4 S-Line, Bora 130 Sport Decked, Toledo TT comp Wheels, some other stuff, Alfa's etc. 1st car 1986 Polo Coupe S.
    May 2011
    136
    Quote Originally Posted by murran View Post
    My bad ! Still talking in R32 language lol !
    James I assumed it was the rears as the front looks like there's a bit of life left !
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,519
    as J said the rears dont have wear indicator
    if the fronts look fine its common for the plugs to get wet etc give the plugs a good clean and make sure there seald togeather
    pauldazzle's Avatar
    Cardiff
    639
    Easy to test PDC sensors. Put the ignition on & select reverse, put your ear up against each sensor, & you should hear them clicking if any don't click they're faulty.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    StuG808's Avatar
    1.9tdi130 Avant FailWheelDrive
    Feb 2012
    Glasgow
    255
    Be happy that these are the only problems you have! Gripes I normally have about my cars are more along the lines of not getting cylinder liners to sit flush or terminal rot destroying the chassis!
    May 2011
    136
    Anyone know how to get around my bonnet dilemma ?
    Pull the lever in the cabin , bonnet pops up ! Lever between the rings pops out half ish !
    Pull the lever as normal and nothing !!
    Mar 2008
    Dorset
    13,856
    If you can't open the bonnet I understand it's possible to do so from underneath with several socket bar extensions, at least then you'll be able to see whats wrong. If the lever is coming out a bit maybe it just needs lubricating?
    May 2011
    136
    Managed to get the bonnet open tonight ! As James said it needed a damn good clean and lube !!
    Looks like I'll be doing the slow wiper repair on Friday after work (half day).
    As for the rear PDC all the sensors are lightly buzzing (clicking) when reverse is selected ???
    T0m
    Sep 2007
    Lichfield
    458
    Quote Originally Posted by Stubie View Post
    I have the same issue with my fronts and people are advising me that its the control module, had it in Audi and they never found any error codes with them bit weird really!!
    Alan H's Avatar
    Need a V8 or Bi-Turbo.......
    Aug 2010
    Dudley, West Midlands
    453
    My front pads looked fine when the brake pad sensor came on. When I changed them they were near enough to the metal. Once the pad warning light comes on there isn't that much life left in the pad.
    May 2011
    136
    The bad luck avant strikes again !
    Took my son to footy training and when driving back , noticed the windscreen had cracked !!
  1. So fed up!!
    By ramos333 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2011, 07:55
  2. Getting fed up
    By smudge_don in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th August 2010, 16:59
  3. Ever Get Fed Up With Your Car!
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2009, 08:17
  4. Fed up with this weather...
    By voorhees in forum General Chat
    Last Post: 29th July 2007, 01:17
  5. Just fed up..!!
    By Sinny71 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd May 2007, 12:49
