JMB RetrofitsChris Nott
Results 1 to 25 of 25
    Feb 2012
    London
    91
    Aftermarket System switch off with Engine/Key Out
    Installed an aftermarket system but it stays on after engine is off and key is out.
    I want it to switch on with engine and switch off too .. how do i do?
    Thank You
    Oct 2009
    Hull
    1,437
    You talking stereo?
    You need to take a feed from under the steering wheel to a relay which will power the stereo
    Feb 2012
    London
    91
    Yup im talking bout a stereo and what you just said made me shiver .. a feed from steering wheel ..??
    Can you elaborate please
    THanks
    Jan 2011
    611
    All audio units have what is known as a switched live, your aftermarket unit should have 2 power feeds to it, one permanent so the unit keeps all it's radio codes etc (normally a yellow wire), the other a switched live which powers up the unit when the ignition is turned on/turns it off when you take the key out.
    Did you fit it yourself, if so the instructions should have made this quite clear, if it was installed by someone else, take it back and tell them to sort it.....
    03MY 52 reg 1.9 TDi 130PS Quattro Sport Avant - 170bhp remap, RNS-E+OEM bluetooth, B7 wiper arms/blades, 4300K HID+nightbreakers/LED sidelights, rear tints, new lights all round, new front/rear screens, frt armrest, s-line kit, cruise/DIS, B7 gearknob/aluminium trims, parking sensors, black grilles, RS4 RARB, S4 front end, black 18" RS6 alloys
    Still waiting..... S4 rear bumper, exhaust tips, coilovers, leather recaro's.... phew...
    Feb 2012
    London
    91
    I fitted it myself .. no instructions coz second hand unit.
    I got 2 yellow feeds but one is not in use and a red feed .. guessing its ignition
    Jan 2011
    611
    There should be a wiring diagram on the back of the unit if not do an internet search to see which connection goes where......
    Feb 2012
    London
    91
    theres no wiring diagram ...
    yellow cable is battery right?
    and red/pink is ignition ..??
    Jan 2011
    611
    Wouldn't know...... someone on the internet or the manufacturer themselves should be able to give you a wiring diagram....
    Jul 2011
    Cornwall
    205
    Make and model number of head unit would help.
    This would enable use to help find the ignition live lead rather than just connecting up any loose lead you find, thus damaging your new head unit.
    Feb 2012
    London
    91
    oo yeah ... its an xtron td714g
    Feb 2012
    London
    91
    i shall take a pic today and post it tonight ... please keep an eye for it slappy
    Jul 2011
    Cornwall
    205
    Jul 2011
    Cornwall
    205
    You might have to email the manufacturer for the installation diagram as all I can find are photos but not the diagram.
    http://www.xtrons.com/Files/ContentI...8155028380.jpg
    Feb 2012
    London
    91
    This is the diagram on top of the system ...
    [IMG][/IMG]
    http://s17.postimage.org/x3zlebhe7/I...226_233951.jpg
    Jul 2011
    Cornwall
    205
    Yellow is battery/permament live/+12v/continuous/memory whatever you like to call it
    Red is ignition and/or switched live, this wire needs to be connected to your fusebox as it's needed to switch your system on and off
    Black is your ground or earth
    Hope this helps
    Tony
    Jun 2003
    World of my own
    9,813
    You can either take a feed from the fusebox to connect to the red switched feed to the HU but this will turn the HU off when you kill the engine, or you can use the proper accessory feed from the ignition switch which stays live until the keys are pulled out.
    Wiring in a proper accessory feed (ignition on) for aftermarket HU install
    Alex Turner
    Jul 2011
    Cornwall
    205
    Andy
    Which relay did you use for your feed? A standard switching relay?
    Tony
    Jun 2003
    World of my own
    9,813
    Yes just a standard 12v 5amp relay
    Alex Turner
    Jul 2011
    Cornwall
    205
    Thanks Andy
    rawtor51's Avatar
    Jan 2011
    Aberdeen
    221
    I know on VW's you just need to swap the red and yellow wires around, I.e plug the red into the yellow and the yellow into the red, this will help the radio keep the programmed stations .
    Can anyone else confirm this please.?
    I don't want him blowing up his car cause u said to swap some wires around.
    Ross, MK5 Golf - R19 DUB, Audi A6 C6 - R19 RRW
    Jun 2003
    World of my own
    9,813
    No on all Audi's 2000+ do not have a switched live at the HU, they use the CANBUS (data line) to tell the stock HU when the ignition is on, so you have to wire in a feed if you want this feature or buy a CANBUS emulator, however there is no guarantee this will give you the proper keys out switch off as it varies from car to car and it's an expensive gamble at £60 a pop.
    Alex Turner
    Feb 2012
    London
    91
    Quote Originally Posted by slappy View Post
    Hope this helps
    Tony
    Red wire needs to be connected where in the fusebox?
    THanks
    Jul 2011
    Cornwall
    205
    Quote Originally Posted by jay786 View Post
    THanks
    Get a multimeter and check the wires behind the fusebox for a switched live, the multimeter should display a voltage of approx 12v when the ignition is on and 0v when it's off.
    Apr 2007
    Wirral
    196
    Fitted a head unit,sub and amp on an a3 on the weekend.
    The ignition live wire is a black and yellow wire. But do check as mentioned before to make sure you have the correct one.
    I also fitted a fuse inline with this wire when I tapped in to the wire in the fusebox to make sure its safe.
    Sep 2011
    West Sussex, UK
    111
    I used a canbus emulator on mine. as it not only gives you the switched 12v but also outputs for the dimming, brake and mute etc.
  1. Replacing bose sound system with aftermarket
    By Davey1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2010, 22:25
  2. A6 Allroad Ignition Key - doesn't switch off systems when pulled out
    By deskboy231 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd March 2010, 09:49
  3. Aftermarket headunits - igntion switch
    By audi18tdan in forum In-Car Entertainment
    Last Post: 18th December 2009, 21:39
  4. Switch Feed to Aftermarket headunit
    By Kev_M5KPL in forum In-Car Entertainment
    Last Post: 9th December 2008, 22:18
  5. Ignition key switch sticky!!!!
    By Daz A3 TDI 130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2008, 18:20
