Badger5Sky Insurance
Results 1 to 10 of 10
    Feb 2012
    13
    A4 1.8t stalling
    Ok got a 1.8t s line and it started losing power going up hills the other day and the next day it would start but stall while idling. If I put it in gear and try starting it it won't start but when in neutral I can keep it running by revving it although a little lumpy. I took the cat of and checked that as someone said it may be blocked. Also I changed all 4 coil packs today but with no difference. It is running quite rich and my spark plugs were black when I cleaned them earlier. Any help would be much appreciated or better still if any one knows a gd mechanic near Taunton in Somerset to come sort it?
    Feb 2012
    13
    No ideas anyone?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    you really need to get it scanned
    for fault codes
    bez101's Avatar
    Jul 2008
    8,491
    just an idea unplug the maf and try it
    Feb 2012
    13
    Ok where's the maf? Sorry just new to trying to sort things myself
    bez101's Avatar
    Jul 2008
    8,491
    the maf is on the pipe comeing from the airbox
    bez101's Avatar
    Jul 2008
    8,491
    its under this cover you cant miss it
    0698-050-engine-480.jpg picture by bez0435 - Photobucket
    Feb 2012
    13
    Ok yeah will try that ta. So say it still stalls when I unplug the maf? Any ideas from there?
    Feb 2012
    13
    Ok unplugged the maf and the car runs. Still got a rattle when in idle and its there when I take my foot off the accelerator just alot faster. Sounds like a helicopter at that point. But when idle sounds like a tapping from behind the engine somewhere
    bez101's Avatar
    Jul 2008
    8,491
    noise could be anything from a heat shield to the DMFW
    does the engine shake at idle ?
    does it increase with the revs ?
    but just get a new MAF then that problem is solved
  1. 2.8Q stalling again
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2011, 23:49
  2. stalling ?
    By dave1x2000 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th October 2010, 13:12
  3. stalling
    By wackojacko in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2007, 08:06
  4. Stalling 2.8Q
    By doeboy in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th February 2007, 23:07
  5. Stalling A3
    By a3daveo in forum General Technical / How To
    Last Post: 4th December 2005, 15:09
