EM TuningMonster Motorsport
Results 1 to 18 of 18
    Jan 2011
    durham
    256
    front wheel bearing life expectancy!
    i always drive with the radio on! been doing motorway driving alot and ran a while with radio off im sure the o/s front wheel bearing is just starting to hum! not that noticable at the mo! car has 106 k on clock! im doing all 4 disks and pads in the next month or so should i replace both in fact should i replace all four bearings while im on! car is a quattro!
    Oct 2009
    Hull
    1,433
    if you want peace of mind and can afford to replace the lot then do it
    are you sure its a wheel bearing and not tyre noise?
    Jan 2011
    durham
    256
    i will find out on sat as im getting 4 new boots! my 2 rear tyres are below the ware markers! ns front has 1.7 mm on and o/s front is about 5 mm im wondering if this is causing it! i got the wheels off my avant when i bought it and chucked my 19s on it! all tyre are differant makes! might be this!
    Oct 2009
    Hull
    1,433
    could be
    you can only try and see i have a hum on the rear off side and im getting 4 new tyres tomorrow if it doesnt go then i will be buying a wheel bearing or two
    simon.m's Avatar
    Oct 2009
    2,746
    i read they are meant to last the life of the car in the hanz manul but i dont think they can say that as they dont no how long the car will last ;-) i get the same sort of thing but thinking its tyer mind mine is on 149k now so id think they are up for it soon lol
    Jan 2011
    durham
    256
    hope it is the tyres! seems a bit twitchy over uneven surfaces too at the mo it never used to be! cant complane thou had it for 5 years an shes cost not alot!
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,689
    Quote Originally Posted by vorsprung dork View Post
    Depends what profile they are.
    Jan 2011
    durham
    256
    define osmosis!
    Sep 2010
    167
    You can normally tell if its tyre noise or wheel bearing, does the noise change when you steer when driving? Steppped tread can make wheel bearing type noise, If you run your hand along the tread it should be fairly even , if not can cause noise similar to a wheel bearing.
    Jan 2011
    durham
    256
    will let you all know sat afternoon after new tyres!
    Quote Originally Posted by quattro tony View Post
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    im at 215k miles and my ones are fine,
    dolcevita4's Avatar
    Feb 2012
    Durham
    68
    get it on a jack and spin the wheel.. you will know straight away if its the bearing or not, i've had to do mine ( i think it depends on how you drive ) i've bought a premium one (68 pound each) from andrew page, put them on and one was faulty... so the job had to be done again but at least ive learned how to do it myself ( using my friends hydraulic press)
    Jun 2003
    World of my own
    9,813
    Just had my nearside one replaced, on 150k so can't complain, my previous B6 Avant one went at 160k so seems about typical, 215k is very good
    Alex Turner
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    My old FWD needed the front bearings done at ~150k.
    The quattro had a rear done before i baught it (~90k) which failed in relatively short order (fitters had damaged the seal!), the other rear became noisey and after replacing both of them i realised one of the fronts had started making a racket too, i ended up changing all four by 120k.
    TD5 Land Rover Defender build
    StuG808's Avatar
    1.9tdi130 Avant FailWheelDrive
    Feb 2012
    Glasgow
    255
    On some cars the 'wiggling a jacked wheel' doesnt always tell of a wheel bearing failure. The most obvious is the 'whump whump' noise from a wheel when on a long steady turn, such as a motorway turn off.
    dolcevita4's Avatar
    Feb 2012
    Durham
    68
    also this might help; when my bearing was worn, the noise was getting quiter when breaking.. but when i lifted the car up and span the wheel there was a clicking noise so i knew it was the bearing.
    Jan 2011
    durham
    256
    4 new tyres and shes still singing! 4 new barings coming right up! i recon doing doughnuts in the snow for the last two winters has had an adverse affect on the mo fows!
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    mine was horiffic when i brought it @ 70mph ish and it was the tyres causing it
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
  1. Life expectancy for exhaust system
    By mikeyw in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 12th July 2011, 17:04
  2. A3 2.0FSI Wheel Front Bearing
    By Maverick001 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th November 2010, 17:27
  3. Anyone had a new front wheel bearing fitted on their A3?
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2010, 18:38
  4. QUATTRO RUNNING GEAR LIFE EXPECTANCY?
    By iwantthatone in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th February 2010, 22:58
  5. DIY S3 Front wheel bearing....
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2009, 21:32
