EM TuningBadger5
    Feb 2012
    London
    91
    When do you Change Glow Plugs
    How do you know when your glow plugs need to be changed?
    Whats the purpose of a glow plug?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    The glow plugs pre-heat the chamber to enable the diesel to combust easier as it enters the cylinder.
    They're normally replaced when the car turns over several times before starting.
    Jul 2010
    184
    Does it crank over quickly too many times before starting or is the cranking slower?
    Mine cranks quickly then just about starts.
    Oct 2009
    Hull
    1,437
    Before replacing the glow plugs just try this
    Put the side lights on before trying to start
    There is a common problem with the headlight switch that causes the car to turn over a few times before it will start
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by PhilW View Post
    The glowplugs won't affect the cracking speed, thats more battery dependant.
  1. Do we change glow plugs as part of a service/interval?
    By RobMorris in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2012, 01:52
  2. Need new glow plugs
    By Jord in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th January 2012, 09:42
  3. Glow Plugs
    By DaveA3-TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2010, 10:45
  4. new glow plugs
    By gaz88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd March 2010, 20:44
  5. Glow plugs
    By jojo in forum Diesel forum
    Last Post: 10th October 2004, 23:36
