EM TuningAH Fabrications
Results 1 to 27 of 27
    Feb 2012
    London
    91
    Error - Solenoid Valves for engine mounting short to B+
    I have got this error coming on the diagnostics .. is this realted to car shaking alot and making noise because my car shakes alot.
    How can i resolve or fix this problem.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    have a look at the rear gear box mount m8, just had mine replaced with my DMF and CLUTCH
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Feb 2012
    London
    91
    how much did it cost you to change dmf and clutch
    simon.m's Avatar
    Oct 2009
    2,746
    the engine mount with the solenoid on it is just off to the right hand side when looking from the front of the car you can see it. have a look at the 2 wires going to it see if they have snaped
    Feb 2012
    London
    91
    ANy pictures to show me ..
    What is it near?
    Thanks and sorry for being dumb
    simon.m's Avatar
    Oct 2009
    2,746
    i dont have any mate but you cant miss it if you look down the right hand side by the inside wheel arch you will see it it has 2 wires coming off of a round dome looking thing
    Feb 2012
    London
    91
    What part do i have to buy or replace?
    simon.m's Avatar
    Oct 2009
    2,746
    you can normally re do the wires if not its the hole engine mount i think
    Jul 2011
    mids
    1,193
    mine was showing engine mount fault but it was picking the knocking up off the knackered split rear one on the gear box, dmf clutch, rear mains oil seal, gearbox mount cost me around £600
    A4 TDI 130 SPORT..
    Feb 2012
    London
    91
    I dont know what to look for .. the cables seem okay ... so whats the error for?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    It's telling you the engine mount is knackered.
    Feb 2012
    London
    91
    oh okay so how do i know which one to change?
    How much are they?
    THanks
    simon.m's Avatar
    Oct 2009
    2,746
    as far as i know there is only one engine mount that has the solenoid on it and thats the one on the right hand side that you can see
    Feb 2012
    London
    91
    okay but if its telling me this one is worn out ... what about the other one?
    Both been put into place same time .. how would i know if the other one is not knackered
    Mar 2008
    Dorset
    13,856
    These engine mounts are 'electric' - when a current is passed through them they will stiffen up, thus at idle the mount will be softer to minimise the vibrations, but it will stiffen up at speed. The other mount (assuming there's only one on the 1.9's?) is a normal rubber mount so will not have the electric feature. This is a very common failure on A4's.
    Jun 2009
    186
    Its the passengers side of the engine and theres only one.
    Feb 2012
    London
    91
    Are u sure theres only one .. i saw two circular dome thing on a 1.9 TDI?
    If its one im so happy .. please confirm?
    Jun 2009
    186
    One AFAIK. Phone Audi parts and ask them.
    Jul 2011
    mids
    1,193
    theres two fitted to your car one with wiring and one without !! ive got a brand new without wiring from audi still in the box
    A4 TDI 130 SPORT..
    Feb 2012
    London
    91
    Do i change both ...
    How much?
    Feb 2012
    London
    91
    anyone got pictures of both
    Jul 2011
    mids
    1,193
    you wont want the bill for changing both m8, nearly £80 for the one without wiring expect the other to be more, did you check the rear gearbox mount ???? this was causing mine to pick up knocking and gave me that code...........
    A4 TDI 130 SPORT..
    Feb 2012
    London
    91
    no i havent .. gearbox mount .. wheres that located?
    Feb 2012
    London
    91
    what do i loook for ... how much will that set me back?
    Jun 2009
    186
    If youre getting a code for the mount, its the electric one. Its very likely to fail. The other is not.
    Dont get ahead of yourself, change the mount, then think of the rest.
    Feb 2012
    London
    91
    its just if i do both at once .. id save on the labour and get it done once and for all
  28. #27
    Mar 2008
    Dorset
    13,856
    Why don't you take it in to someone who knows what they're doing?
    It seems that everything we mentioned you want a price for. Take it somewhere and get them to establish exactly what's wrong and go from there, I don't see this idle speculation is getting anyone anywhere.
  1. Engine mount solenoid valves
    By mattyboyc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th May 2013, 22:07
  2. ZF short to ground error
    By Crgmcd in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2012, 23:03
  3. Engine mount solenoid, what is it?
    By cathalferris in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th August 2006, 21:23
  4. S4 engine mounting
    By imported_timwiti in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th September 2005, 17:01
