Badger5Chris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 78
Like Tree1Likes
Thread: Audi A4 1.9 TDI - Temperature never reaches 90 Degrees
    Feb 2012
    London
    91
    Hi People,
    For some reason the engine temperature never reaches 90 Degrees. its always on the 70 Degree mark or below to be honest.
    I only get heat from my heating system when im driving, not when im idle .. blows out cold air.
    Plus .. i get less air coming into the vents. When i open up all four vents or split the heat to the floor .. you cannot even feel anything thats coming out. Its as if its not sucking in enough air to give out.
    Please help
    kite's Avatar
    Oct 2007
    East Berks
    675
    I would change the thermostat
    A4 (b6) 2.5 TDi QS Saloon.
    Sep 2009
    95
    I would say it’s your temperature sensor easy to replace
    Feb 2012
    London
    91
    Shall i replace both or the thermostat first and then the temperature sensor
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    your problem is the thermostat m8 temp sensor will only tell the gauge to go to it's desired temp it's reading..... thermostat is stuck open causing it not not reach running temps in the first place......
    you may well be best to change both items as they dont cost that much to buy £25-35 ish for both
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Feb 2012
    London
    91
    Is there a guide on how to change it.
    THanks
    simon.m's Avatar
    Oct 2009
    2,746
    its best to do both as they are both in the same housing when you take it off for the stat you will see the temp sensor
    Feb 2012
    London
    91
    Any pictures or how to do it .. i have bought the temp sensor as well as the thermostat
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I can almost guarantee that every question you ask has been asked before if you look:
    just changed the coolant temp sensor on 1.9tdi. a quick how to while its still fresh.
    Oct 2009
    Hull
    1,442
    Quote Originally Posted by simon.m View Post
    You sure?
    My stat is at the front and my sensor is at the rear both opposite sides too
    simon.m's Avatar
    Oct 2009
    2,746
    it says its on the rear on a tdi mate
    StuG808's Avatar
    1.9tdi130 Avant FailWheelDrive
    Feb 2012
    Glasgow
    255
    Hmm, I'm replacing the only the thermostat on mine tonight. If I had read a bit more about the temp sensor I would have got that ready to change too. I'll see how it goes with just the thermostat change first.
    Oct 2009
    Hull
    1,442
    The temp sensor is at the rear on mine and the stat is at the front behind the alternator
    Some engine codes could be different though mines an avb
    pink.teg's Avatar
    Jan 2012
    Cardiff
    170
    Woo hoo
    best of luck !!
    Im doing both in the morning
    ready for the remap ......
    So may in the same. Boat !!!
    Lancaster
    1,782
    Did our A6 last night. Easy job! 90 degrees after 12 mins
    To do: None yet.
    Oct 2009
    Hull
    1,442
    Quote Originally Posted by BlackQuat View Post
    Is this after 12 mins of driving? It take the missus 30 mins to get to work and only just reaches temp this is with a newish stat! Maybe I have a duff stat!
    Lancaster
    1,782
    Quote Originally Posted by stu_m View Post
    Yeh bud, the wife took it to work today and she said by settle (12 mins away) it was at 90degrees and on the way home after 5 mins it was just coming off 60degrees and another 5 mins later it was hot.
    My v6 tdi is at full temp in less than 10 mins though, i think it has aux heating though.
    We fitted a new stat, temp sensor and new fluid.
    To do: None yet.
    dolcevita4's Avatar
    Feb 2012
    Durham
    74
    I'd do both in one go, it's cheap enough ! Apart from these two parts you will need coolant to top it up.
    dolcevita4's Avatar
    Feb 2012
    Durham
    74
    my a4 1.9 tdi gets on temp after 7-8 mins.
    30 mins is way too long, i would check that out and have it fixed as it's pointless wasting money on fuel...
    Lancaster
    1,782
    As above it needs sorting. The wife took it down to Chester the other day, 190+ mile round trip at 70 degrees. Ouch.
    It had the original black sensor on too. Gulp! MPG has been showing 46 on the dash, run back today showed 55mpg
    To do: None yet.
    dolcevita4's Avatar
    Feb 2012
    Durham
    74
    I mean if your handy with your tools it will cost you around 20 pound for the whole lot, so it's definately worth it.
    Jul 2011
    mids
    1,193
    have known a few spurious make thermostats to fail from new so may be worth investing in genuine imo...
    A4 TDI 130 SPORT..
    Feb 2012
    London
    91
    The temp sensor is on the rear ... what is it near .. my engine is 100bhp .. is that engine code AVB?
    simon.m's Avatar
    Oct 2009
    2,746
    you have the same engine as me as you look down the back you can see it mate
    Feb 2012
    London
    91
    so for my model is the temp sensor and the stat in 2 different location?
    Is the temp sensor below the engine?
    simon.m's Avatar
    Oct 2009
    2,746
    as far as i no it is in the same housing mate but i did not change mine when it was done so cant be 100% sure but nether of them are hard to change i think its nearer the drivers side near the top
  28. #27
    Oct 2009
    Hull
    1,442
    Quote Originally Posted by jay786 View Post
    Yes the temp sensor is on the left as you look at the engine drivers side right at the back it is hard to see
    And the stat is at the front right passenger side right behind the alternator just lower then it look for the bottom rad pipe and follow it to the engine
    And yes 100 bhp is avb engine code check your v5 to verify
  29. #28
    Oct 2009
    Hull
    1,442
    Well I will be doing cam belt and water pump some time soon so I will change stat and sensor again while I'm at it this time I will get them from Audi
  30. #29
    simon.m's Avatar
    Oct 2009
    2,746
    the book says its beneath an inlet elbow/cover on the left hand side of the cylinder block thats the haynes manual
  31. #30
    Feb 2012
    London
    91
    damn i bought mine from eurocar parts
  32. #31
    dolcevita4's Avatar
    Feb 2012
    Durham
    74
    don't worry, i have mine from them and never had any problems.
  33. #32
    Oct 2009
    Hull
    1,442
    left if your sat in the car thats the way haynes describes it ;-)
  34. #33
    simon.m's Avatar
    Oct 2009
    2,746
    ha well its there some where hehehe
  35. #34
    pink.teg's Avatar
    Jan 2012
    Cardiff
    170
    well well
    all done changed both parts this morning 30.mins max
    90'c now lets hope it dosen't over heat in traffic ......
    £48.72 from trade parts specialists that's a supplier to Audi
  36. #35
    StuG808's Avatar
    Feb 2012
    Glasgow
    255
    Quote Originally Posted by pink.teg View Post
    well well
    Did you have to drain the coolant to do the job? I didn't get round to doing mine as the service took most of the night (and also dealing with a snapped dipstick tube!).
  37. #36
    Feb 2012
    London
    91
    where on earth is the thermostat located on a 1.9 TDI 100bhp ... can't find it.
  38. #37
    Feb 2012
    London
    91
    i was told behind the alternator .. cannot see it .. do i need to take out my alternator?
  39. #38
    Mar 2008
    Dorset
    13,856
    I can't imagine it's that hard to find!
    But if you're really stuck I'll have a look on Elaswin for you tonight.
  40. #39
    Feb 2012
    London
    91
    Thats my engine bay .. someone please locate the thermostat.
    Oct 2009
    Hull
    1,442
    As already said follow the bottom rad hose to the engine it will come to a plastic pipe remove this and your stat is in there
  1. TDi 130 Temperature Guage
    By MarkWizard in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd February 2011, 10:38
  2. temperature gauge a4 tdi problem
    By neal in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2010, 16:01
  3. Temperature Gauge Hitting 120 Degrees?
    By stevewicks in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2010, 14:32
  4. A3 TDI temperature problem help needed
    By TurboDave in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2009, 15:14
  5. The wrath of Barry reaches far and wide
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th February 2009, 22:57
