AH FabricationsVolks Autos
Results 1 to 8 of 8
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,110
    Faulty servo going down hill ???
    On my sons A4 1.9TDi 2002 when going down inclines the servo seems to become intermitant with the pedal sudenly becoming very hard and not working ... he also reports the pedal going all the way to the floor though i was unable to get it to do this ... i've checked the fluid level which seems fine .... i'm wondering if there's a vacume hose that could have split thats getting pulled open when the engine learches forward..... anyone had a similar experience or know what it might be ??? it's obviously a dangerous situation to be in
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Mar 2008
    Oldham, Manchester
    1,110
    Bump..... comon guys i really need some feedback on this as i'm not happy with him driving it... master cylinder seems fine as there's no creep when holding the pedal pressed hard .... and they work fine other than when braking whilst going down a steep hill
    Jun 2010
    25
    Have a read of this post on the RAC forum. Audi A4 Brake Failure Problem
    May be of some help.?
    Mar 2008
    Oldham, Manchester
    1,110
    Brilliant , thanks for that , i have something to start looking at now ... sounding like the water issue to me then with maybe the water sloshing forward moreso on a hill and then being dragged into the servo... i had heard about this water problem but didn't realise it could effect the brakes ... thought it just made your carpets wet... i shall also check my avant now then though i've had no problems so far touch wood
    dolcevita4's Avatar
    Feb 2012
    Durham
    74
    I have had the same situation on mine 1.9 tdi 2002, but it only appeared when cold and also when i was driving downhill, stiff pedal. What happened is that my drain holes were blocked and the water got trapped. There was a lot of water and it entered the servo which then froze. I had to get the servo out and get rid of water which cured the problem.. indeed it's very dangerous. I've almost went through a roundabout
    Mar 2008
    Oldham, Manchester
    1,110
    Right i've told my lad to check for water around the battery area as i'm un able to look at it till weds as i'm workin shifts and he reports that yes he can see water down there ... do too deep but deffo some water... where is the bung that gets blocked ? is it directly under the battery ?? do you think i could suck any water out of the servo with a sryinge and some flexible pipe... i really wanna avoid pulling the servo out if i can help it ... in the mean time i've told him to shove some old towels down there to try and soak up some of the water thanks for thwe help guys
    Mar 2008
    Oldham, Manchester
    1,110
    Found the Sticky on this issue....
    dolcevita4's Avatar
    Feb 2012
    Durham
    74
    take the battery out and directly under the servo there is drain hole, poke it with screw driver and the water will run down, unfortunately I had to take mine out.
  1. Changing Servo Anyone Done It?
    By Martin82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2011, 23:05
  2. Faulty MAF? Faulty Spark Plugs? Faulty Ignition Coils?
    By Wizza in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2011, 23:00
  3. Brake Servo ?
    By A3 T in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2011, 17:46
  4. Brake Servo Issue?
    By tux in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th January 2011, 00:20
  5. Brake servo has died.....
    By Bigman in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd January 2008, 15:31
