EM TuningJMB Retrofits
Results 1 to 9 of 9
    Sep 2008
    Nuneaton, Mids
    237
    Driver side front indicator playing up.
    i tried searching but found no real useful info regarding this.
    a couple of days ago my indicator started clicking at double speed - so I presumed that I had a bulb out. so checked and yes, the front wasn't blinking. Off I go to my local parts place and buy a pair of 581's them set about the task of removing the headlamp tto change the bulb - After twisting off the old bulb, it looked totally fine - filament unbroken and no sign of it blowing. I decided to put in the replacement anyway.
    popped on the ignition and tried indicating right - click click click click - still not working.
    does anyone have any clues as to what's going on here ? all the other indicators aand lights work perfectly, it's just this one
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Does it have power going to it?
    Sep 2008
    Nuneaton, Mids
    237
    I'm afraid I don't have a multimeter so can't check. there was one point when re-attaching the headlamp when it seemed to work. but once it was all screwed back in it was dead again.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    check fuse
    maybe the hazard switch
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by unitzero View Post
    In that case I'd check all connections at the plug and inside the headlight unit.
    Sep 2008
    Nuneaton, Mids
    237
    check fuse
    would the hazard fuse not cause both inductors to act up ?
    James, I shall check the connections as soon as I can get hold of something to check with, may pop to my mates garage and see if I can borrow his tools
    (like usual)
    Sep 2008
    Nuneaton, Mids
    237
    update:
    Pushed out all the sprung pins / connectors within the indicator bulb holder and where it screws in to the housing and *touch wood* all is well. managed to fit 2 white side lights and my other Philips extreme dipped bulb too.
    thanks for the help
    Jun 2003
    World of my own
    9,813
    Thats really wierd, exactly the same thing happened to me last week. Changed the bulb and it worked OK for a few days then back to double speed again. I did exactly what you did with the bulb holder only yesterday and all is well. It was the drivers side also, very bizarre!
    Alex Turner
    Sep 2008
    Nuneaton, Mids
    237
    the springs must sag over the years and decide not to make contact a they should ? I'm sure if it keeps happening a new holder shouldn't be too much £ from Audi.
  1. Rattling noise from front driver side
    By sanj_c in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2010, 23:33
  2. Condensation in side indicator...
    By cooltempo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2010, 12:32
  3. My A6 driver side indicator fades away ? Why ?
    By Swiftphones in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th January 2009, 23:55
  4. Indicator Relay Playing Up
    By pazaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2008, 17:42
