EM TuningMonster Motorsport
Results 1 to 9 of 9
    Mar 2011
    24
    Air coming back through air filter....? Sticky valve?
    Hi,
    How you all doing? I have a quick question here, I think I maybe already have the answer but looking to see if anyone else has had the same problem. When my A4 1.9 TDI is under load it is pushing air back out the engine and through the air filer intake, I have ran some Forte in the diesel for a week and has helped slightly but looking for any other suggestions before I strip it down for a rebuild, pressuming it is a sticky valve (need to get a 2nd opinion at my mates garage!)
    Mar 2011
    24
    Anyone got any ideas here? Going to have a look at this at the weekend as now the car has a power issue when under load on the motorway it doesnt really want to go over 3000 revs!
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    the way you make it sound m8 seems like a turbo issue to me bud hopefully someone may of had this issue and beable to help better
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Mar 2011
    24
    Cheers for the reply. I had a look at this afternoon as I had time and had a second opinion on it, I have a worn cam shaft
    Few good details here:
    PD130 Cam Followers do wear sorted by R-Tek THANK YOU!!!! - uk-mkivs
    Camshaft lobe lifter wear on VW Audi TDI PD engine and replacement DIY
    The video sounds excatly what mine did, so anyone with the same issue this should fix it for them aswell...
    Jul 2011
    mids
    1,193
    ouch !! that sounds expensive
    A4 TDI 130 SPORT..
    Lancaster
    1,780
    I'd be tempted to try the DIY Turbo Vane sticking in the how2 section first bud.
    To do: None yet.
    Jul 2007
    London
    3,240
    take the rocker cover off mate and see if the cam is worn,. If it is budget for 500-700 quid to have it done. Make sure you buy new injector holding bolts if you go for it !
    FOR SALE:
    Jul 2011
    mids
    1,193
    i have a very good 2nd hand turbo if required but as said check the cams m8....
    A4 TDI 130 SPORT..
    Mar 2011
    24
    I can get a brand new cam, lifters and upper/lower bearings for around £200. I will be able to fit it myself. It got a timing belt kit and water pump 10K ago, so I will most likely just fit a new belt. Will get the rocker cover off this weekend and see if its defo a worn cam before ordering the parts.
    Adam - have you done one before, is that why you recommend the new bolts?
  1. Woosh of air coming out of k&n airfilter ????
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2011, 10:17
  2. 2.8 v6 fuel filter location + which air filter
    By audi1664 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2010, 21:50
  3. Replies: 4
    Last Post: 1st September 2006, 09:16
  4. Replies: 11
    Last Post: 13th July 2004, 16:05
  5. Air Intake/Air Filter for my new A4
    By Joeyz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th July 2004, 20:15
