KowalskiEM Tuning
Results 1 to 12 of 12
    StuG808's Avatar
    1.9tdi130 Avant FailWheelDrive
    Feb 2012
    Glasgow
    118
    Post Thanks / Like
    1.9tdi 130, n00b owner, fuel filter query
    Hello, I've had my 2003 A4 Avant 1.9 tdi 130 for a week so far and I'm loving it. We bought it so that the dog would stop muddying up my Eunos Roadster but I'm actually seriously falling for this car in a big way!
    I've always had older cars and carried out maintenance and repair, and although this car is (for me) rather new and posh, I still hope it can mostly be maintained by DIY.
    So far I've repaired the glovebox hinge (thanks to the moderator on here for the guide)
    Unblocked and decoded the old RNS-D
    Replaced bulbs
    I have noticed today that a fluctuating buzzing noise began to emit from the rear-right of the car. Tracking it down it seemed to come from the rear amplifier area but continued even with it disconnected. After looking around on the net, it seems that it could be the fuel filter. Is this probably the main source of the issue? The only odd thing is that is was still doing it with the car turned off..
    Also, the previous owner changed the cambelt, but with no receipts I'm not going to take his word for it. Are there any good guides for this job?
    edit> also, I'm doing a search for the fuel filter but I get two types, one is a more expensive £60 type and the other is a £15 type but both look totally different. Which one would I need?
    ie, as in the following links:
    02 03 04 05 06 Audi Fuel Filter 8E0201511G A4 Base Cabriolet: Amazon.co.uk: Car & Motorbike
    www.vwspares.co.uk
    StuG808's Avatar
    Feb 2012
    Glasgow
    118
    Post Thanks / Like
    Just been out to the car and it's still making that noise even though the ignition hasn't been on for about 6 hours.. surely this can't still be the fuel pump making the noise?
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    The alarm siren is there, it's not that is it?
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    Jan 2011
    durham
    234
    Post Thanks / Like
    if for some reason your alarm has been going off when your not around! the batterys in your alarm siren will have died! you cannot replace these batterys!! you have to buy a new siren! v expensive! i had this problem on an a3 the rear wiper motor had started leaking onto the boot lock causing it to short out and open the boot of its own accord thus setting the alarm off! buy the time i had sussed it the siren was goosed! so i just disconected it cause to be honist who takes any notice of a car alarm going off! hope this helps!
    StuG808's Avatar
    Feb 2012
    Glasgow
    118
    Post Thanks / Like
    had a quick look, I can't see the siren. I looked in the compartment where the amplifier and the sub woofer is, it seems like it's coming from the amplifier, but still does it when disconnected. It could be the alarm siren as it makes a similar fluctuating sound, but more like a low volume buzzing, but surely this would stop when the keyfob lock button is pushed? I need to sort this as not only is it irritating, but it'll flatten the battery..
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    You can replace the batteries:
    Alarm Siren Replacement Guide?
    StuG808's Avatar
    Feb 2012
    Glasgow
    118
    Post Thanks / Like
    Interesting point regarding the alarm battery, I guess the way to test if it still works is to sit inside the car, set the keyfob to lock and then start the car? I imagine that would set an alarm off?
    Jan 2011
    durham
    234
    Post Thanks / Like
    siren has its own battery as if some one was to disconect the battery to steel your motor alarm would still work!
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    Quote Originally Posted by sgibson808 View Post
    Lock the car with the remote and wait 30 secs. Then unlock the drivers door with the key in the lock and see if it goes off.
    Jan 2011
    durham
    234
    Post Thanks / Like
    disarm the interior alarm buy the button in the drivers door pocket sit in the car with the doors locked and wait and see if the boot open symbol comes up on your dash if it does its your boot lock! i
    Jan 2011
    durham
    234
    Post Thanks / Like
    is this the same on an a3 on an 03??
    rawtor51's Avatar
    Jan 2011
    Aberdeen
    160
    Post Thanks / Like
    yeah , i say its the alarm battey too, my A3 also did this.
    Ross, MK4 Golf - R19 DUB, B6 Avant - R19 RRW
  1. A6 1.9tdi 130 help please
    By paul20v in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 11th November 2010, 22:02
  2. How to replace pollen filter and fuel filter?
    By spence_star in forum General Technical / How To
    Last Post: 20th April 2010, 07:59
  3. 2.8 v6 fuel filter location + which air filter
    By audi1664 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2010, 21:50
  4. Best Panel Filter for the 1.9TDI 130?
    By Mason-A3Sport in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th September 2009, 17:37
  5. OIL FILTER QUERY
    By sjl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th May 2007, 18:42
