JBSAMD Technik
    Jan 2012
    Kilmarnock, Scotland
    48
    Post Thanks / Like
    Stupid power question
    Has anyone ever rolling roaded a standard 1.8t quattro sport? And what did it make?
    I had mine done on Saturday and it made 185bhp. I can't decide if its a very good standard engine, bad mapped engine (Told it isn;t mapped) or just a bad dyno operator (although some of the other runs seemed pretty accurate)
    Alais DJA's Avatar
    Feb 2012
    Southampton
    501
    Post Thanks / Like
    Quote Originally Posted by vroomtshh View Post
    Firstly, what year.... i also have the 1.8T QS.
    Jan 2012
    48
    Post Thanks / Like
    Sorry its an 03, so should be 161bhp standard
    May 2011
    213
    Post Thanks / Like
    that is probably one of the most subjective questions you can ask,.
    No two engines are the same, the same can be said for the dyno.
    For example your engine may have more or less miles than others, or in better or worse condition, not to mention the dyno you had yours run on could be running 15bhp above true, someone else might have had theirs done at 5bhp above true, etc etc.
    So im afraid you wont have anything clarified from your question
    2002 B6 A4 1.9 TDi 130 Sport with fully factory Votex kit.
    Currently standard
    Jan 2012
    48
    Post Thanks / Like
    Quote Originally Posted by Grangey. View Post
    I know all of the above. Hence the reason for asking the question.
    I'm trying to work out why the power was what it was. I (generally) don't believe that the car would be 185bhp, but going from other readouts on that dyno on that day, most other outputs were fairly accurate.
    So that would suggest the dyno was reasonably close (i.e. other standard cars were +- 5bhp from where they should be)
    I wasn't sure if that model generally rolls higher than it should. I've heard of manufacturers under quoting before, so the next model up looks better. I also know there are plenty of 180bhp variants of the same engine.
    I'm not particularly interested in the actual numbers. Just wondered if its normal for them to read high. The fact that intake temps were just slightly above freezing certainly can't have done any harm :lol:
  1. Stupid question i know
    By FinnMc1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2011, 23:27
  2. Stupid Question....I think..
    By paddy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th August 2009, 20:59
  3. Stupid question? :-)
    By DaveMK^ in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2008, 18:23
  4. help !! stupid question
    By phil739 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th November 2006, 15:35
  5. Stupid Question
    By jdp1962 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th October 2004, 19:51
Click Here To Chat Live
