Revo TechnikEM Tuning
Results 1 to 10 of 10
    Jan 2012
    Ireland
    Post Thanks / Like
    A4 Leaking Coolant
    Hi all,
    I have an A4 1.9 TDI 130 Bhp 2004 that's leaking engine coolant badly. I have tried everything but cannot find the source of the leak. The harder I drive, the faster the coolant leaks. For example Drive easy for 50 miles = 1/4 litre coolant, Drive hard for 50 miles = 1 and 1/2 litres. Basically it emptys itself when driving hard. I've already replaced reservoir bottle and cap, water pump, thermostat and seal, plastic seal connection at rear of block, i've tried bypassing the heater rad, changed all hoses and clips. There is no sign of a coolant leak anywhere under the bonnet. I'ts been like this now for almost a year. It doesn't overheat as long as you keep it topped up as soon as the coolant low light comes on in the dash ( I'm running on water with the last while, the coolant was getting too expensive). The engine oil looks normal, recently changed. There is no sign of water coming from the exhaust. I'm thinking the head or head Gasket but don't realluy want to touch it until i'm positive that this will fix the problem. Any Thoughts?????
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    Have the coolang.system pressure checked
    A4 (b6) 2.5 TDi QS Saloon.
    Jan 2012
    Ireland
    Post Thanks / Like
    I've also had the cooling system pressure tested and there was no pressure drop. Also just to note that the leak is only present when the engine is running.
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    Have it sniff tested. That will test for hydrocarbons in the coolant and prove a head gasket failure
    marktdisport's Avatar
    Jul 2011
    midlands
    692
    Post Thanks / Like
    just out of curiosity when was the water pump last changed m8... is there any chance it's leaking from the little tell tail hole ive seen this before but it also leaked after a good run when the engine was swithed off, if i remember it was a b5 tdi i done this job on and water pump cured it
    A4 TDI 130 SPORT..
    AU01 A4's Avatar
    Jan 2009
    Huddersfield
    210
    Post Thanks / Like
    Have You Checked the coolent bleed valve?
    Audi A4 1.8T quattro S Line Avant
    Jan 2012
    Ireland
    Post Thanks / Like
    Thanks for your replies....
    Water pump was changed about 5 months ago? Absolutely no signs of water around the pump.
    Where is the coolant bleed valve located?
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,257
    Post Thanks / Like
    Head Gasket
    Do you want £5k a month, every month, for working 3 hours a week part time ? I'm serious, open the link!
    http://www.makeandsavecash.com
    AU01 A4's Avatar
    Jan 2009
    Huddersfield
    210
    Post Thanks / Like
    sorry for the late replay, been on the road,
    see link
    Coolant bleeder screw PN request # 2... - AudiWorld Forums
    Nov 2011
    16
    Post Thanks / Like
    Same as turkster.. Sounds very like the head gasket has gone.I've recently went thru the same with my 1.9 tdi mk4 golf.. Tried many new parts and all that was left to do was the head gasket.. Not had any more coolant problems since..
    M
  1. Leaking coolant Hose From Oil Filter on S4....
    By s4best4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2011, 22:24
  2. Leaking coolant?!?
    By A3_'99_Tsport in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd July 2010, 22:54
  3. Coolant temp. sender flange leaking, why?
    By 2.0 8v in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd July 2010, 22:25
  4. Coolant leaking
    By jamo79 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th March 2009, 13:05
  5. A4 S-Line leaking coolant
    By Manics in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st July 2008, 21:03
Click Here To Chat Live
