AMD TechnikKowalski
Results 1 to 7 of 7
    Oct 2009
    Hull
    495
    Post Thanks / Like
    Suspension arms!
    Are they all the same or is there different ones for sports models?
    I have replaced 3 off the top ones a while ago and I'm about to replace another
    But I have noticed that on one side of the car my tyre has worn on the outside edge and at one point it looked as if the camber angle was well out on that wheel
    I'm pretty sure its just the tracking but I just want to make sure
    It's a 1.9tdi 100bhp model now I don't know if its got standard or sport suspension it looks pretty low compared to some I have seen!
    bez101's Avatar
    Jul 2008
    3,409
    Post Thanks / Like
    you should realy get it tracked up after replaceing any of the arms
    Oct 2009
    Hull
    495
    Post Thanks / Like
    Yes I know that but I need to know if the suspension arms are different for sport and standard etc
    The reason I haven't had it tracked is because the tyres where already shafted and you can't track them up on shafted tyres
    Oct 2009
    Hull
    495
    Post Thanks / Like
    Anyone?
    bez101's Avatar
    Jul 2008
    3,409
    Post Thanks / Like
    as far as i know the se and sport are the same arms but wjy dont you give your reg when buying them that way you will get the right ones for your car
    also look on the v5 to see what model it is
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    There's no difference.
    If you're car is a Sport it will have a 3 spoke steering wheel and seat bolsters.
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    Oct 2009
    Hull
    495
    Post Thanks / Like
    thanks guys
    mine is supposed to have standard suspension but it looks lower then some others i have seen around here so not sure if its had sports suspension fitted in the past
    i always give the reg when getting parts but my concern was if the sports are different and they had been fitted then my reg would be no good! but if the arms are the same all is good :-)
  1. Suspension arms?
    By tja in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th December 2010, 22:00
  2. Suspension arms
    Last Post: 28th November 2010, 20:13
  3. Suspension arms
    Last Post: 11th September 2008, 10:37
  4. Clunk from front suspension, not suspension arms though?........
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th June 2008, 21:37
  5. Suspension arms
    By Biglockie in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th April 2008, 14:41
Click Here To Chat Live
