Sky InsuranceChris Nott
    Nov 2011
    33
    Cabriolet Radio Antenna Diagnosis
    Hi Folks
    Just want someone to agree with my thinking on this as i think its the actual antenna in the boot that is the problem now.
    So i ran another cable from the HU to the antenna in the boot and no difference.
    Then tried a normal car aerial i had in the HU and it picked up radio no probs.
    Then i wired in same old car aerial into the cable going to the HU from the antenna (in the boot) and radio worked.
    So i dont think its the cable, and as such must surely be the antenna in the boot?
    DOnt want to buy a new antenna if i'm wrong of course!
    Also what are the other 2 connectors on the unit, black one i imagine would be ground?
    Many Thanks
    Oct 2009
    Hull
    1,440
    Has it got an amplifier that could have stopped working?
    I know when you change the head unit you have to send power down to the amplifier otherwise you get rubbish reception
    Nov 2011
    33
    I changed over to RNS-E from the Symphony or Concert that was in the car but that had no radio working either.
    So i think its the Antenna amp or whatever you call it now.
    Just want to be sure before i spend ze pennies!
    Oct 2009
    Hull
    1,440
    Do you get any radio at all? Mine was really rubbish reception and could hardly hear the radio
    Nov 2011
    33
    Nothing all, just static
  1. Diagnosis port on A3?
    By antnee in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2011, 15:09
  2. DV diagnosis
    By twist123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2009, 08:23
  3. 1998 Cabriolet - Delta Radio/Tape - CD Compatible?
    By Phil Young in forum In-Car Entertainment
    Last Post: 13th June 2006, 14:08
  4. radio antenna problem
    By acex in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2004, 10:46
