Revo TechnikDPM
    Sep 2011
    21
    Post Thanks / Like
    Engine coolant temp sensor
    Easy fix? Any links with pics of location would be great? Any help would be much appreciated. Thanks
    white.akita's Avatar
    May 2008
    county durham
    252
    Post Thanks / Like
    Which engine!
    2002 a4 1.9 tdi quattro avant sport in black, 191,000 miles.
    Sep 2011
    21
    Post Thanks / Like
    Cab 1.8t thanks
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    Cardiff
    187
    Post Thanks / Like
    Can't say I'm too impressed with that guide. Cheap CTS. Use a genuine green VAG CTS as aftermarket, & Ebay ones are notoriously unreliable. (CTS has 2 outputs feeds 1 to the temp guage & the other to the ECU a fault on the CTS ECU output will cause incorrect fueling & running issues).
    It's an easy 5 minute job to do on a 1.8 T VW/ Seat?Skoda as they're tranverse, but a little bit more of a pain on Audi as access is tight. Took me less than 10 mins on my Audi A4 TDI though.
    On the Audi 1.8T CTS is located at the rear of the engine.
    The CTS is held in place by a plastic C clip which in the above guide had maybe been fitted on the wrong side of the CTS housing, which is why he had so much trouble removing it, but as he advised it's worth having a spare c clip on hand.
    Obviously do the job with the engine cold.
    Leave the header tank cap on as it reduces the ammount of coolant loss. Have the new CTS with a new O ring fitted ready to install. Pull the C clip out & pull the CTS up out of it's housing, the O ring usually doesn't come out with it so be ready to dig it out. Put the new CTS in & replace the C clip. Then disconnect the connector of the old CTS ( it's easier to get off with the CTS out), & refit to the new one. Top up the header tank with G12, & check that the CTS has seated properly & not leaking. With header tank cap off & the heater on full hot start the engine & bring it up to temp holding the RPM's up at 2500 until the temp gauge has sat at 90 for a few minutes. Then check coolant level & top up if neccesary. It's important to do this last part to remove any air locks in the coolant system.
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, S Line Kit, Van Aaken Smart Box, Leather, Cruise Control, Bose, Cool Glove Box.
  1. Coolant temp sensor location on 2.0 tdi BLB engine code
    By polo10v in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th November 2011, 15:47
  2. 16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    By dellboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2011, 14:59
  3. Engine Coolant temp sensor circuit 1 high a3 tdi 2.0?PO118
    By aterro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th December 2010, 16:46
  4. Continuous Engine Coolant Temp. Sensor Problem - PLEASE HELP!
    By emzino in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2009, 15:25
  5. Engine Coolant temp and Lambda sensor
    By taj in forum TT/TT-S/TT-RS Forum
    Last Post: 9th March 2005, 13:05
Click Here To Chat Live
