Adrian S FluxForge Motorsport
Results 1 to 20 of 20
    Apr 2010
    Burnley, near monty carlo !!!
    333
    Post Thanks / Like
    Hi all gunna bite the bullet.. help required please for two part numbers
    Hi all im after the two part numbers for the A4 B6 TDi 130 temp sensor and is it the coolant sensor????? Basically my car is averaging constant 37 MPG including A + B roads and motorway running, its chipped but still should be doing a lot better as it used to get mid 40 MPG. so im going to get an awsome GTI re remap done + im going to get rid of the EGR valve and replace the sensors as the temp in the dash never gets near 90.
    Anybody any help with part numbers..................CHEERS
    A4 TDI SPORT with full leather and thats it as standard.Fitted by me.Remap,S-LINE BADGES.S4 Wing mirrors.DIS,Seat Cupra splitter.Rear parking sensors.5k hids+LED side lights+DRL lights+chrome indicator bulbs,amber fog lights.LED Xenon number plate bulbs,upper/lower front grills+boot strip in matt black.Ipod dock.19" BMW X5 SPORT CONCAVE ALLOYS,9 J FRONT 10 J REAR 20mm hub adapters front ET 28,18mm hub adapters rear ET 27.
    TO DO.B5 spring perches.Renault rear diffuser?? S/S exhaust.
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    If your not getting to 90 it could be a failed stat...
    A4 (b6) 2.5 TDi QS Saloon.
    Apr 2010
    333
    Post Thanks / Like
    Quote Originally Posted by kite View Post
    Failed stat ??????????????? whats that.....Theres no way my MPG should be that bad i drive it like a nun!!!!!!!!!!!!!
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    Thermostat...
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    Thermostat. That or the CTS (coolant temp sensor) are good places to start. Neither will break the bank.
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    Lancaster
    1,136
    Post Thanks / Like
    Not sure what kind of job it is to change the thermostat on the 130. It's at the side of the engine against the bulkhead on the PD?
    To do: None yet.
    Greeny233's Avatar
    Mar 2011
    Llangollen, North Wales
    36
    Post Thanks / Like
    i'd change the thermostat first. it's on the right-hand side of the engine just by the altenator.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    Jan 2011
    421
    Post Thanks / Like
    When I had my Cambelt done about a year ago I made them replace the thermostat as well just cos it was a good time to do it...
    2003 A4 Cab 2.4 V6 Manual / 36k miles genuine woohoo / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    167
    Post Thanks / Like
    Ive seen plenty of pics as to where the thermostat is. As Greeny said, is on the passenger side, just behind the alternator.
    Im told you can change it quickly without loosing too much coolant.
    Well i will find out on friday (weather permitant) and update with a few pics if i can as mine needs changing
    The sensor is a little tricky/fiddly to change. You can get to it from the drivers side, up against the bulkhead
    (normally green)
    Prep the new one with new washer before removing the old one, and be careful removing the clip as its plastic
    (ill be able to write a manual after ive finished sorting my little gremlins out on mine )
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    Apr 2010
    333
    Post Thanks / Like
    Has anybody got some part numbers??? sounds like thats were im gunna start then.
    Apr 2010
    333
    Post Thanks / Like
    Any help with part numbers????
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    Apr 2010
    333
    Post Thanks / Like
    Bummer its not for windows 7
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    Lol sorry!
    Do you need the part numbers? Can't you just order from the dealer/supplier? They're fairly common items I would think.
    Jun 2003
    World of my own
    9,427
    Post Thanks / Like
    Just get them from a dealer or GSF, they're not expensive. I'd change the temp sender first as it's a 20 minute job, the stat is much more involved. If it was the stat stuck open the car would reach 90 when stuck in traffic idling, if it was stuck closed then you'd have overheating problems.
    Alex Turner
    Apr 2010
    333
    Post Thanks / Like
    Quote Originally Posted by AndyMac View Post
    Cheers i'll do the temp sensor first then.........
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    167
    Post Thanks / Like
    I changed the sender a few months ago and realised recently that the temp is sticking at 70 again
    Going to change the thermostat tomorrow
    Do you think the sender could have gone faulty again?
    Jun 2003
    World of my own
    9,427
    Post Thanks / Like
    It can happen if you bought an aftermarket one off ebay, unlikely on an OEM part I would think, if you leave the car idling for awhile does the temp rise? Do the fans kick in at any point?
    Alex Turner
    marktdisport's Avatar
    Jul 2011
    midlands
    692
    Post Thanks / Like
    ive replaced a thermostat stuck open and it hardly even moved the guage not even in traffic for ages customer told me they wanted temp sender changing i told them my thoughts was thermostat first, they said change the parts they had brought so done that and guess what no temp guage still, changed thermostat and bobs your uncle and cured, the reason for my thought was the heaters wasn't getting red hot they was warm but not as hot as i thought they should have been.....
    A4 TDI 130 SPORT..
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    167
    Post Thanks / Like
    Checked it last night, had the engine running for a while with the heating the car off. Did not get above 70 ish
    The fan did not kick in at all. It was a tad cold, but i would have thought it would get up to 90
    The sensor i fitting was from the main dealer.
    Was going to change the thermo today, but its been hammering it down all day (no garage)
  1. a couple of part numbers required please
    By DOLPHIN DIESEL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th May 2010, 11:37
  2. Im going to bite the bullet.....
    By Drizz in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th May 2010, 08:30
  3. Part numbers for interior trim required (if someone has a mo)
    By evapor8 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2010, 00:22
  4. S3 Part Numbers
    By Jay.Ing in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th September 2008, 13:14
  5. Part numbers for turbos required
    By clcollins in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2005, 14:45
Click Here To Chat Live
