Hiya people, does anybody no how you change the seat belts on the front of an a b6? My pre tensioners have gone off and I have sourced replacement belts, but don't no how to change them!
Thanks in advance!
Thanks in advance!
B6 A4 Avant 1.8T (190) S-Line
i assume your talking about the belt real that is hidden away in the B pillar between the 2 doors? if you are then the way to change them is to take off all the covering panels and unbolt the units and feed in the new ones in reverse, its not a big job and id advise you disconnect the cars battery 1st, you will need to unbolt the units from the cars chassis.
Do you want £5k a month, every month, for working 3 hours a week part time ? I'm serious, open the link!
http://www.makeandsavecash.com
Thank you turkster, any ideas where to start removing the panels? Searched on here for days and can't find a definitive answer.
Tried brute force and ignorance, just pulled and they came off!
Problem sorted, seat belts replaced. Thanks
ah , alls well that ends, well, happy dayz, just off the cuff, was you ever a member of e36coupe.com ?
