JBSDPM
Results 1 to 22 of 22
    T0m
    Sep 2007
    Lichfield
    310
    Post Thanks / Like
    Headlights......options
    Hey guys need a bit of help, I dont want the hassle of installing HIDs and then having issues at MOT time and as we all know that the B6 headlights are awful so guys what are my options short of installing HID's is it possible to uprate the bulbs to get better headlights at night?
    Lancaster
    1,136
    Post Thanks / Like
    Osram nigth breaker plus.
    Probably the best bulb you'll get. Quattrojames kindly posted up autocars test records.
    To do: None yet.
    marktdisport's Avatar
    Jul 2011
    midlands
    692
    Post Thanks / Like
    ive just fitted these but with the projection junk type of headlight i havent seen much improvment and i had these in my cupra which i seen massive improvments
    A4 TDI 130 SPORT..
    Lancaster
    1,136
    Post Thanks / Like
    I prefer projectors, might be worth a clean?
    To do: None yet.
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    Halogen bulbs are only ever going to get you so so results compared to gas discharge ones.
    If you don't want HID's then retrofitting oem Xenon units is your only other alternative really. But unless you do washers and self levelling rear suspension you still have the potential for mot issues.
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    T0m
    Sep 2007
    Lichfield
    310
    Post Thanks / Like
    Looks like I'll be living with what I have then :-( ha ha thanks guys!
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    There are plenty of uprated bulb options which will improve your lights, but none that will match the performance of HID's.
    itsmeagain's Avatar
    1.8T Sport Cabriolet
    Mar 2010
    West Midlands
    431
    Post Thanks / Like
    I have HIDs fitted to my A4 cab, it's been for 2 MOTs since then. I have never had any issues with them at all.
    Audi A4 1.8t sport convertible, Full Grey Leather Interior, Ambient Light Pack, Polished Forge FMCL007P Diverter valve, Green Cotton Filter, 100mm Tail pipes, Rear RS4 ARB, Interior Xenon White LED's bulbs, Xenon White LED number plate bulbs and side lights, JBS Auto Designs stage 1 remap, RNS-E and OEM Bluetooth, Remote roof module, OEM Wind Deflector, B7 rear lights, HID lights.
    Oct 2009
    Hull
    495
    Post Thanks / Like
    Quote Originally Posted by itsmeagain View Post
    As of this year the rules have changed I put a post up about it a couple of weeks ago
    The test center can fail you for not having self leveling and headlight washers they never used to be able to
    Jan 2011
    421
    Post Thanks / Like
    This s what I did A4 Cab 2003 bulb upgrade pic
    2003 A4 Cab 2.4 V6 Manual / 36k miles genuine woohoo / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    PetrolDave's Avatar
    Nov 2003
    U.K.
    811
    Post Thanks / Like
    Quote Originally Posted by stu_m View Post
    This is an urban myth that is being put about, but it is NOT TRUE - read the actual Inspection Manual here MOT Documentation Contents Page
    See Section 1.7 where it says:
    "Vehicles equipped with High Intensity Discharge
    (HID) or LED dipped beam headlamps may be fitted
    with headlamp washers and a suspension or
    headlamp self levelling system.
    Where such systems are fitted, they must work;
    however, it is accepted that it may not be possible
    to readily determine the functioning of self levelling
    systems. In such cases, the benefit of the doubt
    must be given."
    The key word is MAY, note it doesn't say MUST. So you can still pass the MOT test if you have HIDs but don't have self-levelling or washers - but if those are fitted they must work.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0200) with AMI (250GB hard disk), Bluetooth + HTC Touch HD
    simon.m's Avatar
    Oct 2009
    2,579
    Post Thanks / Like
    if you have hids and it falls the mot just pop your old lights back in for the re test and then swap back after i could not go back to normal lights now after having my HIDs in just so much clearer
    Oct 2009
    Hull
    495
    Post Thanks / Like
    Quote Originally Posted by PetrolDave View Post
    must be given."
    hmmm interesting
    i posted this a bit back and the link is where i got my info from!
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    This is from Vosa, dated March 2011 but with reference to the change in MoT legislation from Jan 2012:
    http://www.dft.gov.uk/vosa/repositor...3-lighting.pdf
    Therefore, in order to pass the MOT test, vehicles fitted with after-market HID systems would also need to be fitted with headlamp cleaning and self-levelling systems.
    That seems quite clear, but this does introduce an element of doubt:
    Where headlamp levelling or cleaning devices are missing or defective, but there is doubt as to whether they are required, the benefit of the doubt should be given and an advisory notice issued.
    ..... although there isn't really any 'doubt' that they'd required from the first quote.
    Jan 2012
    Kilmarnock, Scotland
    48
    Post Thanks / Like
    The official handbook issued to mot stations, says what petroldave stated.
    I have a copy at work that is in PDF, if anyone can host it, I can email it to them.
    It's very clear that levelling and washers is a MAY be fitted, not a must.
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    The official handbook would be published by Vosa would it not?
    Odd that the same authority is offering two different stories.
    Jan 2012
    48
    Post Thanks / Like
    IMO its not two different stories. What you posted is from early last year. There were about half a dozen updates, until they came up with the final version which has now been issued to mot stations.
    My only worry would be that the construction and use regs still say xenons require levelling and washers, so although they can pass an mot, they are still technically unlawful, meaning you could still be done at the roadside
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    Quote Originally Posted by vroomtshh View Post
    If that ends up as the case then it won't be too bad. You be pretty unlucky to get a ticket for well maintained and adjusted 6000k bulbs in a projector headlight, and if it eliminates the dazzle from 12000k bulbs in reflector headlights then it can only be a good thing.
    Just need to work out what's happening with remaps now! Lol.
    simon.m's Avatar
    Oct 2009
    2,579
    Post Thanks / Like
    im thinking of putting some thing like this on mine just to be safe although id get smaller ones and then all id be missing is the self levling but as far as i no that cant be tested BMW 5 SERIES 528I E39 1996-2003 HEADLAMP WASHER JET (DRIVER) | eBay
    Jan 2012
    48
    Post Thanks / Like
    No mention of Remaps in the manual. Diesels still don't need a cat either.
    IMO they'll never be able to check remaps. How could an mot station possibly keep records of every standard map for every model of car, and check it against what's currently running?
    May 2011
    213
    Post Thanks / Like
    pah theres a lot of stuff you "NEED" for Mots, just like I "needed" a catalytic converter on my last two civics.... they still went through fine.
    For something as minor as HIDs, youl probably find in 9/10 cases that a simple call to your smaller local independant MOT tester explaining you believe your cars HIDs are aftermarket, and simply asking whether theyed be willing to pass it to save you swapping out for standard bulbs for the sake of one day will get you further than you think.
    You have to also remember alot of these testers are human aswell, so if they passed you with aftermarket HIDs even if it was completely illegal to do so- whats to stop the tester saying they werent present for the test and were clearly swapped? Its a minimal thing for them to pass really and I think most of them realise that.
    2002 B6 A4 1.9 TDi 130 Sport with fully factory Votex kit.
    Currently standard
    Mar 2008
    Dorset
    10,964
    Post Thanks / Like
    Quote Originally Posted by Grangey. View Post
    Sadly that seems to work both ways...!
  1. Does my B7 have hallogen headlights or Bi-xenon headlights
    By a4man in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th December 2011, 22:04
  2. S3 Options
    By Dave1000 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2008, 21:32
  3. Changing A3 headlights to Facelift headlights
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2008, 17:18
  4. 96 Audi headlights changed for 98 face lift headlights
    By K7ERG in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 24th January 2007, 17:41
  5. Vehicle options / Vehicle options coding
    By A4 2.0T in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th September 2006, 22:55
Click Here To Chat Live
