Help
I have a 2.5tdi with a battery drain, it all started after the pendulum chamber was flooded a couple of months ago, I've takin the car to two auto electricians the 1st who had the car for 2 weeks but he couldnt find the fault to fix it, and the 2nd took the radio out and checked the central control unit out.(which was fine as it was bone dry when I inspected it myself after the flood in the pendulum chamber)
The symptoms are.
The hazard warning switch lights up for 2 seconds then goes off for 10 seconds even when the alarm is turned off, also when the alarm is turned on the L E D on the drivers door flash's as normal but every fourth flash it double flash's.
I have found that there is a 0.8amp drain at the same time as the hazard switch lights up, I've also pulled every fuse out of the fuse box but i still have the 0.8amp which is killing my battery over 3 days if I don't use the car.
Would greatful for any advice
LinkBack URL
About LinkBacks
2003 Audi A4 2.5 TDi quattro SE
