Sky InsuranceBadger5
    da4
    da4's Avatar
    Apr 2008
    Belgium
    7
    Post Thanks / Like
    Question Left front speaker is not as loud as the one on the right
    Like the title says,
    Left is pretty quiet ,my friend also has this with his passat b5.
    Its the standard speakers with a single din radio.
    Jun 2003
    World of my own
    9,427
    Post Thanks / Like
    I'd first remove the rubber boot between the door and the A pillar and try cleaning the connector underneath as these can get full of crap. This usually results in intermittant problems which go away when you jack the volume right up, but it could also give a low volume all the time. Also pull the HU and check the brown ISO connector on the back, ensure it is firmly plugged in. While your there you can snip one of the skinny leads paired with the fat leads which will kill the awful centre dash speaker and improve the sound no end.
    Alex Turner
  4. Thanks da4 thanked for this post
  5. #3
    da4
    da4's Avatar
    Apr 2008
    Belgium
    7
    Post Thanks / Like
    Alright,will try to clean the cables and will let it know how it turned out.
    About the center speaker,i don't think there is one in there,i'm not using a standard radio.
    Something i don't get is why i have lower soundvolume on the left and my his Passat B5.5 has the exact same problem.
    It used to keep playing but the last weeks i got no audio on the left front.A little wack against my door and its fine again .
    *edit ;its left hand drive btw so the drivers speaker
    A4 Avant B6 '02 TDI 130 5 manual - 155342 miles and counting - Dolphin Grey
  1. Left speaker abit intermittant
    By Grangey. in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd December 2011, 15:31
  2. Buzzing from left rear speaker, bose half amp
    By bodiepro in forum In-Car Entertainment
    Last Post: 4th February 2010, 16:21
  3. Loud creeking noise from front
    By afcjay in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2009, 15:32
  4. Replies: 7
    Last Post: 1st September 2008, 12:43
  5. Duff front left BOSE speaker (S3)
    By mramcha in forum In-Car Entertainment
    Last Post: 7th April 2008, 00:28
Click Here To Chat Live
