JBSRevo Technik
    Mar 2009
    11
    Post Thanks / Like
    Question A4 B6 2000 intermittent fault
    Hi could anyone advise regarding a fault with my A4.
    The alarm has been going off, the rear doors remain shut (despite trying to open them from the inside and out), Interior lights are on and off and central locking has a mind of its own. These are just some of the faults which are all intermittent.
    I have done some reading up and it seems that the blame points to Central Convenience Unit. So I stripped the interior passenger area to expose the module and to my shock it seems to be dry as the Sahara. The surround wires are also dry, I also inspected the module for dry-joints and found it to be spot-on.
    Can anyone one advise where the fault may lie?
    Any help on the matter is greatly apprecited.
    Grover
    marktdisport's Avatar
    Jul 2011
    midlands
    692
    Post Thanks / Like
    it will need fault code scanning m8 could be a number of things,
    A4 TDI 130 SPORT..
    Mar 2009
    11
    Post Thanks / Like
    I have scanned it and the fault changed when I scanned it. I will try and post the latter scan.
    Thank you
    Grover
    Mar 2009
    11
    Post Thanks / Like
    Scanned after clearing all DTCs
    VCDS-Lite Version: Release 1.0
    Sunday, 15 January 2012, 22:58:00:0
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
    Address 01: Engine Labels: Redir Fail!
    Controller: 8E0 909 557
    Component: 2.0L R4/5VS 0003
    Coding: 0011501
    Shop #: WSC 63351
    1 Fault Found:
    17701 - Map Controlled Engine Cooling Thermostat (F265): Short to Plus
    P1293 - 001 - Upper Limit Exceeded - Intermittent
    Readiness: 0010 0001
    Address 08: Auto HVAC Labels: 8E0-820-043.LBL
    Controller: 8E0 820 043
    Component: A4 Klimaautomat 0711
    Coding: 00000
    Shop #: WSC 63351
    2 Faults Found:
    00819 - High Pressure Sensor (G65)
    07-10 - Signal too Low - Intermittent
    01333 - Door Control Module; Rear Left (J388)
    49-10 - No Communications - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.LBL
    Controller: 8E0 959 655
    Component: Airbag 8.4E 3001
    Coding: 0010602
    Shop #: WSC 63351
    No fault code found.
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
    Controller: 8E0 920 950 D
    Component: KOMBI+WEGFAHRS. RB4 D14
    Coding: 00400
    Shop #: WSC 00001
    WAUZZZ8E82A014675 AUZ6Z0A0145618
    3 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    01337 - Interior Door Handle Illumination
    49-00 - No Communications
    01339 - Door Warning Light
    Address 56: Radio Labels: 8E0-035-1xx-56.LBL
    Controller: 8E0 035 186
    Component: concert II GRO 0008
    Coding: 00201
    Shop #: WSC 00000
    1 Fault Found:
    01042 - Control Module; Not Coded
    35-00 - -
    End --------------------------------------------------------------------------------------------------
    Individual module scanned
    Sunday, 15 January 2012, 23:01:23:0
    Control Module Part Number: 8E0 959 433 AL
    Component and/or Version: Komfortgerát T9F 0514
    Software Coding: 07883
    Work Shop Code: WSC 63351
    Additional Info: 8E2959802B Tõrsteuer.FS BRM 4.11
    Additional Info: 8E2959801B Tõrsteuer.BF BRM 4.11
    14 Faults Found:
    53-00 - Supply Voltage Too Low
    01334 - Door Control Module; Rear Right (J398)
    01338 - Signal; Doors Not Closed
    01326 - Control Module for Multi-Function Steering Wheel (J453)
    01332 - Door Control Module; Passenger Side (J387)
    01351 - Communication Wire at/to Ground (GND)
    37-10 - Faulty - Intermittent
    01590 - Igniter for Battery Disconnect (N253)
    35-00 - -
    01595 - Tire Pressure Control Switch (E226)
    35-00 - -
    01597 - Drive Battery Pre-Charge Circuit
    35-00 - -
    01729 - Switch for Seat Height Rear Pass. Seat (E66); Down
    08-10 - Control Limit Surpassed - Intermittent
    00496 - Sensor for Vehicle Leveling; Front
    00490 - Right Rear Vent Temperature Sensor (G406)
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    Any help on the matter is greatly appreciated
    Grover
  1. Intermittent Fault codes
    By Nutkin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th October 2010, 13:21
  2. 1998 1.8 T intermittent engine fault
    By fin18t in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2009, 20:51
  3. Annoying Intermittent Fault
    By scoobyra in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2009, 19:58
  4. Intermittent Fault Warnings
    By A4Owner in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th June 2003, 11:23
Click Here To Chat Live
