AMD TechnikJBS
Thread: fault code
    bez101's Avatar
    Jul 2008
    3,408
    Post Thanks / Like
    fault code
    17606 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2
    P1198 - 35-00 - Electrical
    from vcds wiki
    17606/P1198 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2: Electrical Malfunction Possible Causes
    • Failed O2 sensor heater circuit
    • Wiring Harness issue
    • Failing ECM
    Possible Solutions
    • Inspect and test O2 sensor heater circuit as per repair manual
    • Inspect and test wiring harness as per wiring diagram
    • Replace ECM if O2 sensor and wiring harness are to factory design
    whats the ECM ?
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    engine control modual. ecu basically.
    you need a new lambda sensor most likely. check the resistance thru the heater circuit on the sensor itself.
    bez101's Avatar
    Jul 2008
    3,408
    Post Thanks / Like
    cheers murran
    would that be the pre cat lambe or the 1 after the cat ?
    Banned
    Aug 2010
    1,043
    Post Thanks / Like
    b1 s2 it says.... s2 = sensor 2 = post cat sensor.
    s1 being the pre cat sensor.
  1. I got a fault code - help please. Code 18057.
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2011, 10:29
  2. Replies: 2
    Last Post: 19th December 2010, 20:41
  3. fault code help please
    By s3_stig in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2010, 06:36
  4. Replies: 5
    Last Post: 18th January 2010, 23:36
  5. fault code help
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th June 2007, 23:43
Click Here To Chat Live
