Monster MotorsportEM Tuning
Thread: Locking Problem
    May 2004
    9
    Locking Problem
    Hi
    I own a 2004 A4. Basically it will not lock when using the fob.
    When I use the key all doors lock besides front passenger. Aud said something to do with air pressure locking. Has anyone else experianced this or know what the Hell I have to do to remedy it. For obvious reasons not being able to lock my car is an inconveniance.
    Your help would be greatly appreciated
    imported_Macduff
    Re: Locking Problem
    I don't think the A4 uses pneumatic locking. It's almost certainly a dirty or faulty microswitch in the catch mechanism. Had the same problem on our Bora. New catch was 60. Probably could have cleaned it up if I'd had the time
    Nov 2004
    London UK
    2,614
    Re: Locking Problem
    Mine is doing the same sometimes driver door locks.opens sometimes not...same withe passenger and rear doors.....going into garage next week to get it looked at....very annoying!
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Re: Locking Problem
    I had a locking problem on my car and it turned out to be the control unit. Went in for it several times and they insisted it was dirty/faulty microswitches. They also forgot to reprogram ALL my keys afterwards. Needed to go back in to have spare key reprogrammed and then again for the small plastic wallet key.
    Dec 2004
    Wiltshire
    Re: Locking Problem
    Hi, 2004MY A4 is 100% definately NOT vacuum operated CDL...the fault sound like it may be a faulty lock on the NSF...they are sometimes prone to not releasing the deadlocks aswell..next time this happens try thumping the door, be carefull not to dent it, they're quite flexible!!!!!..if the CDL won't work on the fob just put the key in the ignition and press the lock button once, turn off the ignition and it should then work ok
    May 2004
    9
    Re: Locking Problem
    Thanks guys, turned out to be a fuse not inserted properly.
