KowalskiUnicorn
Results 1 to 9 of 9
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    00727 fault code
    demister fault code.
    Is this motor on the glovebox side ??
    A4 (b6) 2.5 TDi QS Saloon.
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    Yes it is. The one with the green linkage:
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    Thanks James.
    Looks like I may have to free up the motor.
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    There was a thread recently where someone stripped down and regreased the motor to good effect. I've not yet done mine as it's currently in the working stage of it's intermittent cycle!
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    Yep seen that thread...thats the plan if I cant free it off.
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    motor removed, worm drive greased with vaseline.
    I still have the fault code but I can now demist the screen.
    Looks like a new motor is needed.
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    Easy job?
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    not too bad James thanks.
    Glovebox out and work nearly upside down in the pax footwell, I'm getting too old for this sort of stuff.
    Because I have retrofitted BT behind the glovebox I had to remove that, also it a bugger getting
    the chilled glovebox pipe back in the hole.
    Splitting the motor was OK, i also popped the motor just of the worm and plugged the motor in
    and run it a few times, also it had to be reset with basic setting on refitting.
    I might remove the glovebox in the week again and just make sure all is OK
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    also if this is the start of the niggely things going tilt an A5 is looking quite inviting...
  1. I got a fault code - help please. Code 18057.
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2011, 10:29
  2. Fault Code help
    By way318 in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th May 2011, 22:20
  3. Replies: 2
    Last Post: 19th December 2010, 20:41
  4. Replies: 5
    Last Post: 18th January 2010, 23:36
  5. fault code
    By 1wheelonly in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd March 2009, 11:52
Click Here To Chat Live
