AMD TechnikKowalski
Results 1 to 16 of 16
    May 2011
    213
    Post Thanks / Like
    Help! ESP & ABS light just came on :( :( :(
    Yep, just like that out of the blue, both the ESP and ABS Light came on. I restarted the car for it to clear, only to come on 30 seconds later. ESP button is unresponsive when its on.
    Any ideas?
    God I hope its not expensive
    2002 B6 A4 1.9 TDi 130 Sport with fully factory Votex kit.
    Currently standard
    Jul 2007
    490
    Post Thanks / Like
    Brake light switch?
    May 2011
    213
    Post Thanks / Like
    ...Are you able to elaborate?
    Currently standard
    bez101's Avatar
    Jul 2008
    3,408
    Post Thanks / Like
    when the brake light switch packs in it puts abs esp light on
    your better off scanning it for fault codes
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    A fault in the brake light circuit can cause this, be it a bulb out or a faulty pedal switch (most common).
    If the brake lights are working fine then it might an abs sensor or something, best bet is to try and get a scan done.
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    May 2011
    213
    Post Thanks / Like
    How much do audi charge for scans?
    How much is a brake light switch and is it something im likely to be able to do myself?
    Currently standard
    bez101's Avatar
    Jul 2008
    3,408
    Post Thanks / Like
    very easy to do
    10 min job but why replace unless you know its at fault
    try your brake lights 1st
  9. Thanks Grangey. thanked for this post
    Likes Grangey. liked this post
  10. #8
    May 2011
    213
    Post Thanks / Like
    any ideas on cost of the switch?
    Currently standard
  11. #9
    bez101's Avatar
    Jul 2008
    3,408
    Post Thanks / Like
    cant rember what i paid was defo under 20 quid tho
  12. #10
    bez101's Avatar
    Jul 2008
    3,408
    Post Thanks / Like
    audi charge to much for a scan where u from
  13. #11
    May 2011
    213
    Post Thanks / Like
    Im in Oxford- so it deffo wont be cheap.
    For the sake of under £20 il give the switch a shot lol.
    Any guides or how tos on it? No idea where to find it!
    Currently standard
  14. #12
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    Its on the brake pedal mechanism.
    If you PM me your email I'll send you a pdf guide, it's pretty simple.
  15. Thanks Grangey. thanked for this post
  16. #13
    Pabs's Avatar
    Jun 2010
    Manchester
    406
    Post Thanks / Like
    Audi charge an hours labour rate for a scan which is over £100 (think its actually £135) which is ridiculous, see if someone on here local has vag com, its definately a worthwhile tool to have
    A4 1.8T 190 S-Line, Stage 2 Shark Performance Map 230 BHP, Pipercross Panel Filter, Forge 007 DV, Blue Flame Performance Exhaust + High Flow Sports Cat, 8k HID Lights, 8k HID Fog Lights, LED Sidelights, LED Number Plate, Front + Rear Ambient Lighting, LED Interior Bulbs, Grooved Dimpled Disks, Ultimax Pads, RNS-E DVD, Tinted Windows, S4 Grill, Votex Rear Skirt, BOSE, Leather, Engine Covers, S4 Mirrors, RS4 Pedals, Gloss Black Wrapped Grills, 19" BBS LM's Summer, 19" RS6's Winter, FK Coilovers
  17. #14
    May 2011
    213
    Post Thanks / Like
    Yep, it does appear to be the break switch.
    Drove for as long as possible to work without using my brakes at all and the lights remained off for a good 5 minutes, a second after I used the brakes they both shot on.
    So il get one of them ordered and hope that sorts it
    I assume my brake lights still work? I havnt been able to check yet!
    Currently standard
  18. #15
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    I doubt they do.
  19. #16
    S3 GAZ's Avatar
    Dec 2006
    Renfrewshire Scotland
    199
    Post Thanks / Like
    £10 ish from audi. 10mins to fit and break your back when your upside down with your head in the footwell lol
    When i did mine. The switch is located on the metal arm of the brake pedal. Just unclip wiring connector and remove the switch. the new one will probably look different as mines did but its probably an upgraded design.
  20. Thanks Grangey. thanked for this post
  1. ESP & ABS light
    By landopanda in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2011, 18:32
  2. ESP & ABS light always on help ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 09:03
  3. abs and esp light on with engine management light
    By madsad1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 18:22
  4. ABS/ESP LIGHT
    By markA4tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th January 2010, 15:26
  5. abs & esp warning light lighting up??
    By codrock in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th July 2009, 13:40
Click Here To Chat Live
