W8 PerformanceUnicorn
Results 1 to 7 of 7
    Nov 2007
    Under the Forth Bridge
    16
    Post Thanks / Like
    Post Drivers Side Footwells Swimming Pool - but not the plenum plugs
    Hi everyone.
    Looking for inspiration...
    A few weeks ago I noticed wet carpets down the drivers side of 2004 A4 Avant (UK RHD Car). Having searched the forum duly pulled the battery and cleared the plenum chamber and drain plugs which were silted up (but no water sitting in chamber). The vax pulled out a good 8l or so of nice clean water (no coolant etc in there).
    Anyway - was in rear footwell today and lo and behold my factory fitted optional extra swimming pool has returned. Admittedly the weather in Scotland has been its usual monsoon - however I had hoped the blocked plenum plugs were the issue.
    Have followed round the door seals to look for tears etc - all seem fine. I haven't come out to open windows as a result of key pressing in pocket by accident or similar. The rear window washer seems fine - so unlikely to be that washer tube leaking.
    Anyone got any top tips here, I would like a few pointers before ripping the interior out and starting again.
    Cheers in advance guys.
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    Possibly the seal around the ECU box on the offside.
    Guide: ESP Light On- Glow-Plug/Engine Light Flashing - Cause & Fix Inside!
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    Nov 2007
    16
    Post Thanks / Like
    thanks for rapid response fellow Quattro fiend! Will have a look.
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    20
    Post Thanks / Like
    Check the rear wash-wipe connection (under the plastic trim). The joint here can fail if it's been cold and you continue to use the rear wash wipe. I glued mine!
    2002 A2 1.4 TDi SE (75PS)
    2001 A4 2.5 TDi Avant Quattro Sport (150PS)
    1995 80 1.9 TDi Avant SE (90PS) Sold
    Nov 2007
    16
    Post Thanks / Like
    Thanks all. Hopefully problem solved. Seal under the ECU box wasn't seated properly. Actually put a lining of a couple of mm of foam under the seal on the ecu side to bring the seal up by a couple of mm to hopefully give a better compressed seal as wasn't much sitting proud. Hopefully should do the job.
    Passed the bucket test anyway.
    I noticed once I had the under steering wheel cover off that the foam backed rubber, behind the carpet, directly under the area was damp so looks like this was the problem right enough.
    Fingers crossed anyway - I'm sure the Scottish weather will test it for me in next couple of days!
    Dec 2011
    Wirral uk
    12
    Post Thanks / Like
    Pull off the windscreen trim also , tap along the edges of screen , pillars mainly , a change in sound will indicate possible
    bonding seal has gone plus a slight windrush at speed . A simple quick check , if your still getting soaked front interior ,
    after doing plenums , ecu etc i was still getinng soaked carpets , o/s/f pillar bonding had gone , windscreen out re bonded
    job done
    gonna getcha
    Dec 2006
    somewhere where the the speed limit is over 150mph.
    57
    Post Thanks / Like
    check the pollen filter housing job done
  1. Drivers side S3 wing.......
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2011, 21:59
  2. Drivers side headlight lower than passenger side (S3 Xenons)
    By devan in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2010, 14:31
  3. Drivers side window
    By kaizokuninja in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2010, 13:28
  4. Blowing hot on pasenger side, can't adjust, ok drivers side.
    By Rhencullen1989 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th November 2009, 13:54
  5. Drivers Side Mirror
    By Seifer780 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd February 2009, 07:22
Tags for this Thread
Click Here To Chat Live
