AWEsome GTIKowalski
Results 1 to 17 of 17
    Nov 2011
    33
    Post Thanks / Like
    LED Sidelights on Cabriolet
    Hi folks, hope you all had great xmas!
    I am after some nice looking sidelights that work well with the Cab.
    Any suggestions?
    Tried a few from ebay and so far even though supposed to be canbus error free have either not worked at all (made weird noises also) or thrown up errors and looked pants.
    Jun 2011
    Wellingborough
    411
    Post Thanks / Like
    hi, i supply LED's for this forum, if you search LED threads then i will be the man you need to see.
    are you after a bright one?
    Nov 2011
    33
    Post Thanks / Like
    Quote Originally Posted by t8ups View Post
    Hi there!
    Something subtle more than ultra bright.
    The cab has plastic covers over the sidelights that kind of glow so too bright would look daft i think....
    open to suggestions of course
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    Myself and several forum members use these:
    501/194/T10 New Mini Light Tower 15 Leds Xenon White by Ultra Leds U.K
    They are a nice colour, last well and have never triggered any errors for me. You need to check fitment for your model before ordering.
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    Jun 2011
    Wellingborough
    411
    Post Thanks / Like
    Quote Originally Posted by Hamilton May View Post
    Hi there!
    Have you got a picture of this cover?
    Trups
    Dec 2011
    Ipswich, Suffolk
    139
    Post Thanks / Like
    any suggestions to some with a cap of sorts?
    SMD ones give off the best light but you can see the unsightly yellow in the lamp holder and it looks crud ..
    Jun 2011
    Wellingborough
    411
    Post Thanks / Like
    im struggling to understand about the cap thing?
    i only stock the smd led and have loads of differant types so if some can get me a picture of how the bulbs sits i can figure it out for you.
    Dec 2011
    Ipswich, Suffolk
    139
    Post Thanks / Like
    Cant get a pic atm but the sidelight lens is clear and the bulb pokes through into the headlight so you can see the yellow of the SMD boards if you look at it .. some LEDs come with a translucent plastic dome covering the sidelight which hides this look ..
    bez101's Avatar
    Jul 2008
    3,405
    Post Thanks / Like
    the cab side lights are at the botton of the light unit and are coverd
    not like the saloon ones
    bez101's Avatar
    Jul 2008
    3,405
    Post Thanks / Like
    leds dont look anygood with the cover
    Jun 2011
    Wellingborough
    411
    Post Thanks / Like
    Ok, i have had a look at the picture on my phone, will have a look later on the laptop and see what will be best, when the side lights are on is the aim of the bulb just to light up the block?
    Jun 2011
    Wellingborough
    411
    Post Thanks / Like
    Quote Originally Posted by Daniel97 View Post
    you dont see the yellow square when the smd is is on tho do you?
    Nov 2011
    33
    Post Thanks / Like
    Yeah just something to light up with a clean white light.
    As said problem is you can see the yellow boards of the LEDs as some holes cut into the cover in the lights. That also means the normal blue bulbs that give a good white light can be seen also
    Dec 2011
    Ipswich, Suffolk
    139
    Post Thanks / Like
    No but its dark then so you don't see it anyway ..
    Jun 2011
    Wellingborough
    411
    Post Thanks / Like
    Guys, i will get a few pictures of differant types of bulbs up and you can let me know what type may work.
    Dec 2011
    Ipswich, Suffolk
    139
    Post Thanks / Like
    okay ...
    Jun 2011
    Wellingborough
    411
    Post Thanks / Like
    Here are the canbus types you could try, which ons do you think would be the best?
    The two flats would have to be supplied with the resistor loom to stop the error as i had the bulb designed for BMW interiors but work in sidelights etc.
    let me know, i dont mind if someone wants to try them, work out whats best and return the ones you dont use?
    Trups
  1. LED sidelights
    By Farmer_Harry in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th December 2011, 22:02
  2. LED Sidelights
    By mccrum in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2011, 20:31
  3. LED Sidelights
    By itsmeagain in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th November 2010, 21:38
  4. LED sidelights
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2010, 09:00
  5. LED sidelights
    By IanMcA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd March 2005, 19:59
Click Here To Chat Live
