JBSEM Tuning
Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By stu_m
Thread: Stupid car!
    Oct 2009
    Hull
    492
    Post Thanks / Like
    Stupid car!
    Just been woken up by a neighbour to say that my indicators are flashing on the car
    This is the alarm but the siren is buggerd
    Now the car won't unlock with the key fob when you press it the hazard warning light will light up but the car won't unlock at all I have tried to sync the fob with the car but still not working
    Any ideas?
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    2,936
    Post Thanks / Like
    I't could the car battery at fault. Q is your carpets wet on passenger or drivers side.
    This thread is very good and could save you alon of many if your Plenum Chamber hold water
    Plenum Chamber Drain Grommets - Every A4 B6 owner is affected by this common fault
    AUDI A4 190T S-LINE.
    Oct 2009
    Hull
    492
    Post Thanks / Like
    Battery is fine and the carpet is dry too also we have had very little rain here
    I have also removed the gromets out the plenum chamber about A year ago
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    scan for faults
    A4 (b6) 2.5 TDi QS Saloon.
    Oct 2009
    Hull
    492
    Post Thanks / Like
    Quote Originally Posted by kite View Post
    scan for faults
    That is the plan when I get home from work but the problem is that I only have the shareware of vagcom so I'm limited to What I can do and I'm not paying 100+ for a scan! I would rather save for it full version
    Just after some pointers
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    look in the vagcom section for a member in your area with full VCDS
    Oct 2009
    Hull
    492
    Post Thanks / Like
    There isn't any I've looked!
    I will try with mine to see if anything comes up if not I will be 250 quid lighter!
    Oct 2009
    Hull
    492
    Post Thanks / Like
    well ive had a look with the shareware version i have and this lot came up
    1 Fault Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    43-00 - Closed
    5 Faults Found:
    01134 - Alarm Horn (H12)
    49-00 - No Communications
    01370 - Shareware Version. To Decode all DTCs
    35-00 - Please Register/Activate
    01369 - Shareware Version. To Decode all DTCs
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    00955 - Shareware Version. To Decode all DTCs
    i know about this one
    its the sounder horn its never worked and has been disconnected for some time now
    any help with the rest would be good
    i can also see that my buttons on the key fob are working but not actually unlocking the door!
    i have recently had some radio issues too where it crackles and goes off and have narrored that to wiring in the drivers door somewhere although the wiring that runs from the pillar to the door is fine and has had a repair in the past
    stu
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    the rosstech wiki shows those faults are to do with bonnet catch, drivers door catch and ultrasonic sensors.
    I would cear the faults and see what comes back.
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    00955 - Key 1 00955 - Key 1: Adaptation Limit Surpassed
    Possible Symptoms
    • Key/Remote Control not operational
    Possible Causes
    • Key/Remote Control not matched
    • Key/Remote Control operated too often while Out of Range
    Possible Solutions
    00955 - Key 1: Lower Limit Exceeded
    Possible Symptoms
    Possible Causes
    • Key/Remote Control Battery low/faulty
    Oct 2009
    Hull
    492
    Post Thanks / Like
    cleared them and the only one that come back is 00955 - Key 1: Adaptation Limit Surpassed
    it comes back straight away without touching anything i only have one key fob too so cant try another
    but if i lock the car and wait for the alarm to set and hazard light to go out when i press unlock the hazard light comes on! the battery is pretty new two but will try another but im rather lost as i was out all day in it with no trouble yesterday!
    Oct 2009
    Hull
    492
    Post Thanks / Like
    Do you think this could be down to a wiring problem in the drivers door? I have just been out to the car and tried all the electrics on the drivers door and the window would not work
    a wobble of the wiring and it started to work again
    just seems a bit strange to me
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    fix the wiring in the door loom, it could be the source of your troubles
    Oct 2009
    Hull
    492
    Post Thanks / Like
    Yeah that's the plan hopefully that's all it is I will report back next week when I get time to do it
    Oct 2009
    Hull
    492
    Post Thanks / Like
    bit of an update on this
    the wiring was shot between the door and the door pillar i have made all the connections good so no crackle on the radio now it was loosing power to the door too so im thinking maybe it shorted out or something setting the alarm off???
    although i still have no remote central locking the fob just wont seem to sync although when the car is locked and you press the fob the hazard warning light on the dash will illuminate!! but there is nothing on the doors
    i also pulled the passenger seat out and checked for water and its bone dry opened up the box for the convenience module and it was dry and no signs of ever having a leak in that area although the box has been open before
    i need a full vagcom really as im stuck without it and im not paying main stealer prices!!
    marktdisport's Avatar
    Jul 2011
    midlands
    692
    Post Thanks / Like
    were's about you live stu someone may live near by you !!! worth a mention
    A4 TDI 130 SPORT..
    Oct 2009
    Hull
    492
    Post Thanks / Like
    I live in Hull, yorkshire
    i intend on buying full vagcom but im skint at the min its always when your skint something goes wrong!!
    Jul 2011
    midlands
    692
    Post Thanks / Like
    lol youve updated hull as your location it was empty earlier lol..... hopefully someone will pop up
    A4 TDI 130 SPORT..
    Oct 2009
    Hull
    492
    Post Thanks / Like
    yeah i know im forever telling people on my own forum to stick their location in and i fail to do my own on here
    added now though
    Oct 2009
    Hull
    492
    Post Thanks / Like
    Fixed
    I disconnected the battery connected it back up and all is fine!
  1. stupid car
    By coatesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2011, 08:06
  2. Stupid clock in my car. !??!!
    By supanova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2011, 23:10
  3. Scraped car in stupid bendy multi story car park (pics)
    By 02audis3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2010, 16:07
  4. Replies: 12
    Last Post: 28th December 2009, 12:29
  5. Stupid Car Names
    By smee in forum Rants & Raves
    Last Post: 18th April 2007, 16:23
Click Here To Chat Live
