AMD TechnikRevo Technik
    Mar 2009
    Derbyshire
    26
    Post Thanks / Like
    1.9 TDi (130bhp) EGR problem or vac / boost leak???
    My 1.9Tdi 130, loses power when accelerating. Which I think is either a vac or boost leak or could be due to recently by-passing the EGR. Are there any simple ways of checking for a vac or boost leak?
    Originally I was getting a massive loss of power between 1500-2000rpm followed by a sudden surge of power and some black smoke out of the exhaust. I decided to by-pass my EGR just using a golf tee pushed into the egr vac hose, this seemed to cure the loss of power for a few days until a similar problem started. The loss of power now isn’t as bad as before and it occurs at a higher but broader rev range. I’m not sure if this has come about as a result of by-passing the EGR without blanking it or whether it’s something I’ve done since whilst tinkering with some of the vac hoses.
    Before bypassing the EGR the garage where I had the car serviced suggested that the (original) problem may be due to a vac leak and gave me a bit of new hose. After by-passing the EGR I thought I might as well make use of the new hose but I only had enough to replace a couple of hoses, so I tried to find the ones which were least awkward. It was after this that the car started to struggle with power again. I suspect I may have snagged something and caused a vac leak. Or I may have caused a boost leak, since I was flexing the pipe from the MAF sensor to the turbo for better access, whilst renewing some of the vac hoses.
    Widemonkeys's Avatar
    Aug 2010
    Durham, Durham, United Kingdom
    274
    Post Thanks / Like
    I had exactly the same issue a couple of weeks ago and I had a tiny hole in one of the braided rubber hoses. Cost me £10 for the hose and couple of hours labour and all is fine now and pulls like a train. It also fixed my hard brake pedal issue aswell.
    02 A4 B6 1.9tdi Avant sport 130bhp, 18" RS4's, Cruise control, Armrest, Ambiant lights, LED number plate bulbs,Pressed number plates, rear RS4 ARB, blacked out grills.
    Wanted : S line front and rear bumpers , S4 lower grill, s4 door blades
    Mar 2009
    Derbyshire
    26
    Post Thanks / Like
    Thanks for the reply! Actually I've noticed recently that the brake pedal is unusually hard just before starting it up, seems ok when driving though. Do you remember which of the hoses it was?
    Aug 2010
    274
    Post Thanks / Like
    It was a hose going from the vacume to the engine. I think that's what the garage said. My pedal used to be hard as nails if I braked and came off and braked again it just kept going. Thought it was my servo until the garage said it was all from the same faulty hose. Brakes are excellent now
  1. 2.0 TDI sounds like it has a boost leak?
    By AidenUK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th August 2011, 16:06
  2. Oil leak 1.9 TDI - EGR
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2011, 14:55
  3. Result!!found my vac leak----i think
    By Jay-a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2011, 16:12
  4. Vac Leak?
    By fast_eddie_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2011, 22:22
  5. boost leak problem
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th October 2006, 08:39
Click Here To Chat Live
