JBSKowalski
Results 1 to 15 of 15
    Sulli's Avatar
    Apr 2009
    The Ghost Town
    47
    Post Thanks / Like
    Parking light (Rear Number Plate) Fault - 2004 S4
    I had a fault light come up saying my parking light was out. Checked and one of the rear number plate lights is out, not the other. I changed it, but still not working. Have cleaned all terminals but still not working. Probably not a fuse as they would both be off the same one, and keen not to start strippinbg bootlining if it could be something simple.
    Any ideas?
    B6 S4
    MillTech
    Uprated Brakes, Braided Lines
    Eibach ARBs
    Carbon Roof
    AMD, 351 BHP
    Best MPG 33.6
    Av MPG 25.5
    Oct 2009
    Hull
    492
    Post Thanks / Like
    Get a multimeter and check you are getting power to the pins inside the recess if you are try bending the prongs on the bulb holder as you could just have a poor connection like I did
    Also while yet have the screws out replace them with stainless if they aren't already to prevent future problems
  4. Thanks Sulli thanked for this post
  5. #3
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    The number plate light holder is a nightmare waiting to happen. I think this only applies to LED bulbs, but have you tried rotating the bulb 180 degrees.
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
  6. Thanks Sulli thanked for this post
  7. #4
    Sulli's Avatar
    Apr 2009
    The Ghost Town
    47
    Post Thanks / Like
    Thanks for the replies. I replaced the screw, which looked like it had snapped and replaced it. No fault showing, for about 2 mins, then fault showed up again. The light actually seems to work, but the fault still shows despite this.
    2 things - where do you get the proper stainless steel replacemnt screws and does anyone know what size they are?
    Do I need vagcom to clear this code?
    B6 S4
    MillTech
    Eibach ARBs
    Carbon Roof
    AMD, 351 BHP
    Best MPG 33.6
    Av MPG 25.5
  8. #5
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    They're M3 x 12:
    M3 x 12 STAINLESS ALLEN BOLT CAP SCREW 20 + 10% EX FREE | eBay
    I just washed my car, and undid and rescrewed my screws today just to keep them from seizing!
    You don't need to clear the fault codes.
    I assume they're not LED bulbs?
  9. #6
    Sulli's Avatar
    Apr 2009
    The Ghost Town
    47
    Post Thanks / Like
    No they're not LEDs. Bit confused if the light is working but fault code still showing???
    B6 S4
    MillTech
    Eibach ARBs
    Carbon Roof
    AMD, 351 BHP
    Best MPG 33.6
    Av MPG 25.5
  10. #7
    Sulli's Avatar
    Apr 2009
    The Ghost Town
    47
    Post Thanks / Like
    I am officially a dope.... when the warning first came up I checked the rear number plate light and it was out, so it tallied. So did my internet searches referencing parking light being the number plate light. Just noticed though that my left sidelight (front) the one that comes on as a parking light when you leave the indicator on with keys out, is out......
    So that explains it, sorry for confusion, new nice bright bulbs on way to match the headlights!
    B6 S4
    MillTech
    Eibach ARBs
    Carbon Roof
    AMD, 351 BHP
    Best MPG 33.6
    Av MPG 25.5
  11. #8
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    Lol - My next post was going to be "Don't take offence, but are you 100% sure its a number plate bulb out warning?"......
  12. Likes Sulli liked this post
  13. #9
    Mar 2011
    East Mids
    438
    Post Thanks / Like
    Chaps, how the chuff did you manage to change the bulb? My left hand side bulb is out and I can get my hand to it but it's so tight a can't get a good grip to get it out. It keeps turning and turning it wont come out! Help?? 👊
    B6 S4 4.2 V8 SILVER SALOON - BEIGE ALCANTARA - BOSE SYMPHONY - DRILLED/GROOVED FRONT DISCS
    TO DO: MILLTEK CATBACK, DRILLED/GROOVED REAR DISCS, RS4 ARBS, ALLOY REFURB, RNS-e. RE-MAP, AP Coilovers,
    Previous Cars
    .:R32 MKIV 3DR Pearl Black (Awesome car), Lexus RX300, Lexus LS400, Mitsubishi Shogun Sport V6, Audi TT Roadster 225, Range Rover Vogue 4.6 V8, Mazda RX8 231, Peugeot 307 CC 180, Subaru Impreza WRX 2.5, BMW520i, Lexus IS200,Golf GTi MKV, Audi A4 1.9TDi 130
  14. #10
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    Remove the headlight. Remove both top screws and just loosen the lower one
    A4 (b6) 2.5 TDi QS Saloon.
  15. #11
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    V8 - you talking sidelight or number plate bulb?
  16. #12
    Mar 2011
    East Mids
    438
    Post Thanks / Like
    Surely removing the headlight will unalign it?
    Yes QJ side light, passenger side.
    Previous Cars
  17. #13
    kite's Avatar
    Oct 2007
    East Berks
    469
    Post Thanks / Like
    The headlight is set with the white screws. You dont touch these. There are 2 torx screws at the top and a lower one, you may need a long driver to reach it.
  18. #14
    Mar 2008
    Dorset
    10,962
    Post Thanks / Like
    I was checking as this is a number plate bulb thread
    Taking the light out will unalign it, but if you park facing a wall and use chalk or tape to mark the beam pattern on the wall that will be good enough. Once the light is out then you can remove the connector from the rear of the unit and the bulb will come out with it.
    I've posted a diagram on headlight removal before.
  19. #15
    Mar 2011
    East Mids
    438
    Post Thanks / Like
    hello all
    well would you adam and eve it...
    it just pulls out of the headlight housing, change bulb - £5.50 from Halfords.. push back in..\
    No need to remove headlight at all
    Previous Cars
  1. Rear number plate light screws
    By mccrum in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th March 2011, 21:15
  2. Help Rear number plate light problem A3!!!!!!!!!!!
    By johnnysalv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th May 2010, 23:02
  3. Rear Number plate Light Holders
    By Davy in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st September 2009, 21:44
  4. Rear number plate light
    By LaSarthe&Back in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2007, 20:43
  5. Rear parking light fault ?
    By ang12el in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th June 2007, 15:41
Click Here To Chat Live
