JBSBackdraft Motorsport
Results 1 to 8 of 8
    Lancaster
    1,136
    Post Thanks / Like
    Powersteering problem - Again
    I've posted this before but nothing really came of it.
    About 6 months ago when it was quite hot, my wife borrowed the car and when she came back she was saying the car's steering was very heavy.
    I took it out and sure enough it was heavy. But if you gave it some revs it would work absolutly fine.
    So without revs it's tough and slight revs it goes light again.
    After a few days, it went away. I drained all the fluid out and put new correct green mineral oil back in. It was fine.
    Then in November we went to Carlisle for the wifes graduation. I had to turn round in a narrow lane. Reversed into a gateway of a field. Pulled out on full lock and it went stiff and has been like this since.
    In the morning it works fine, by the time i've got down the road (2 min drive) it stops working again.
    I'm not sure if this is the pump or the seals in the rack. There doesn't seem to be any leaks and the level isn't low.
    I have a spare pump in the shed ready to go on. I don't want to do this though if it turns out to be the rack. I have heard that the pumps are vano pumps. So I assume theres a valve in there that could go wrong?
    Please god help, I want working steering before my NYE in scotland lol
    To do: None yet.
    marktdisport's Avatar
    Jul 2011
    midlands
    692
    Post Thanks / Like
    sounds like a pump issue m8 have you renewed oil and tried bleeding the system
    A4 TDI 130 SPORT..
    Lancaster
    1,136
    Post Thanks / Like
    YEh, I've put fresh fluid in.
    How do you bleed it? I wonder if i have an airlock?
    To do: None yet.
    Jul 2011
    midlands
    692
    Post Thanks / Like
    usually jack the front up both sides and turn the steering full lock to lock 5-6 times ?? do you get a buzzing noise or any juddering whilst trying to turn when it goes stiff !! think turkster done this recently in a thread with steering faults ill try and find it m8
    A4 TDI 130 SPORT..
    Lancaster
    1,136
    Post Thanks / Like
    Just found a how2 on Audizine.
    It used to make a right noise before the first time it played up. Then when it fixed it's self it went perfectly silent. So I wonder if it is air. I'll try bleeding it tomorrow. I still have a litre of fluid in the garage from when I changed it.
    But I am getting a right noise when i turn the steering at the mo.
    To do: None yet.
    Jul 2011
    midlands
    692
    Post Thanks / Like
    gotta be pump or bleeding m8 but obviously start at bleeding firstly plus it cheaper m8
    A4 TDI 130 SPORT..
    Lancaster
    1,136
    Post Thanks / Like
    I'll give it ago. Failing that. I'll change the pump. Doesn't look the hardest job on this car.
    Just trying to find a how2 for the service mode.
    To do: None yet.
    Lancaster
    1,136
    Post Thanks / Like
    Well. I was going to finish work at 1 and head to the garage to start work.
    Got called to a 4 hour chimney fire which was a nightmare.
    So did nothing with it. But when driving home. I did find the car is fine unless I go either full locks. So I'm starting to think more and more that this is a airlock.
    To do: None yet.
  1. Powersteering full lock squeal when stationary/slow movement - help!
    By kujo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th February 2011, 20:17
  2. Replies: 1
    Last Post: 21st August 2010, 19:41
  3. Tips for powersteering hose change
    By mattpanton in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th July 2010, 11:56
  4. Just bought my first A4 !! PowerSteering Noise*
    By moorheadbrian in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th March 2010, 15:20
  5. brake binding problem / abs light problem
    By brendan in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th November 2008, 20:24
Click Here To Chat Live
