AH FabricationsChris Nott
Results 1 to 14 of 14
    Dec 2011
    Ipswich, Suffolk
    139
    Offset & Tyre Size
    I do not understand this period.
    So my 2003 A4 Avant. What offset are my 16".
    If i buy new wheels - what size offset is the minimum and maximum i can buy .. and what tyre size to i buy in relation to the offset. 18" Wheels btw.
    Thanks!
    Lancaster
    1,637
    18" You want 235/40/18
    I run ET33 which is quite far out. I would think that'd be your limit and i wouldn't advise much higher figures than standard.
    To do: None yet.
    Dec 2011
    Ipswich, Suffolk
    139
    When you say higher you actually mean lower don't you?
    Lower number is further they stick out?
    Lancaster
    1,637
    When I say higher figure i mean if the standard figure is 43 i wouldn't go to 48 as they'll sit too far in.
    To do: None yet.
    Dec 2011
    Ipswich, Suffolk
    139
    Okay so i want between 33-40 really .. not a fan of spacers
    18 or 19 on the Avant?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,712
    You'll not go wrong on ET35 with an 8" wheels, you can go a couple of mm either way with no real issues.
    18's or 19's are personal choice, the forum contains fans of both.
    Dec 2011
    Ipswich, Suffolk
    139
    Any pros & cons for each?
    Mar 2008
    Dorset
    13,712
    Just the obvious.... tyre cost vs ride quality vs looks etc
    Dec 2011
    Ipswich, Suffolk
    139
    so the bigger i go the harsher the ride, more expensive the tyre and looks better (arguable)
    So 18's are my best choice then
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Not true. 19's or 18's give the same feel. I have run both and feel no difference.
    AUDI A4 190T S-LINE.
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Quote Originally Posted by CMD View Post
    On a smooth road maybe
    It standards to reason the more profile of tyre you have the better the ride quality
    Unless you live in a part of the uk that has smooth roads
    That is a very rare place indeed .
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Quote Originally Posted by paul20v View Post
    I live in S. Wales Paul and there are NO smooth roads out here apart from a 500 mtr section of M4 just past Bridgend. The sport suspension on my A4 was firm and now i'm on a combo of coilovers it's still just like the sport setup the 19's or 18's just feel the same to me.. The polo we have Now that's harsh even on a 45 profile.. I feel it's the suspension setup not the wheel and tyre setup
    Apr 2010
    Burnley, near monty carlo !!!
    351
    Quote Originally Posted by Daniel97 View Post
    GO BIG OR GO HOME.....Nar its personnal choice i run 19" X5 alloys 9J front 10J rears with 225/35 fronts and 235/35 rear my front E.T IS 28 just inside the arch and i DO mean JUST and rear ET 27 out of the arch by 6/8 mm but thats because there 10J with 18mm adapters.....
    As for the ride i ran 19" porsche cayannes on my A3 with 215/35s all around and had Eibachs on and the ride was to hard, but with my current setup on the A4 and standard sport springs the rides fine, just avoid potholes....
    A4 TDI SPORT with full leather and thats it as standard.Fitted by me.Remap,S-LINE BADGES.S4 Wing mirrors.DIS,Seat Cupra splitter.Rear parking sensors.5k hids+LED side lights+DRL lights+chrome indicator bulbs,amber fog lights.LED Xenon number plate bulbs,upper/lower front grills+boot strip in matt black.Ipod dock.19" BMW X5 SPORT CONCAVE ALLOYS,9 J FRONT 10 J REAR 20mm hub adapters front ET 28,18mm hub adapters rear ET 27.
    TO DO.B5 spring perches.Renault rear diffuser?? S/S exhaust.
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,579
    For an 8J (8") wheel, the S4 Avus III's are ET45.... I'd advise for going for that as the safety option or within 5mm of that. Between ET45 and ET40 if you can't get exactlyt he same as the S4 spec.
    For looks, I wouldn't go below ET50 - they'll sit in too far.
    Some people will swear by ET33 or ET30, sometimes that looks usable, but it does look more than a litte risky on others as they will stick out a LOT, I wouldn't advise buying anything lower than ET40 unless you have the option to try before you buy.
    LostBok/BahnStormer77
  1. a3 sline 19 " tyre size and wheel offset question
    By andi1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2011, 05:44
  2. S-Line Wheel Tyre Size & Offset?
    By karbonk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th November 2010, 16:54
  3. Offset v handling & tyre pressure advice
    By HerefordQuattro in forum Handling
    Last Post: 31st March 2010, 16:29
  4. A4 Avant 2.5 Quattro wheel size offset + tyre recommendation...
    By motosparkz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th October 2008, 07:49
  5. What size & offset are 17" S4 Alloys?
    By sixsr in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th September 2008, 21:24
