Sky InsuranceBadger5
    Dec 2011
    2004 a4 2.5 diesel cold start problems and white smoke
    Wondering if anyone can shed some light on this for me, got a 04 a4 2.5 163 sport from a guy at work, he's been running it on red diesel for years, got a bad batch started running crap, I got it this week, put it into my mates garage he found water in the fuel filter, took the pump of, full of crap, cleaned etc, drained the fuel tank.. New fuel filter in..
    It struggles to start in the morning, loads of white smoke, its pretty much impossible to move the car till maybe 2 mins after start up and the smoke has cleared. Then it's runs fine until u hit 3000 rpm. Really struggles to go past this and the traction control light comes on at the same time.
    Does anyone know what could be wrong? Ive seen a few similar related problems on the net that suggest maybe the pump timming could be out????
    Getting fault codes 17583 and 00550
    Any help would be much appreciated
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Does sound like fuel pump timing, but could be injector problems from the red diesel, or maybe even a VP44 fuel pump error as the pump won't have taken kindly to that abuse.
    Try the pump codes in the Rosstech wiki to see what they refer to.
    Dec 2011
    00550- injection commencment- petrol or bio diesel, water in fuel system or air in system
    Or fuel links clogged
    17583 Pilot injection shut of- Possable causes are same as above and also Low fuel pressure and internal damaged to the pump
    Feb 2012
    A6 BDG same problem as above...
    Hi,
    Did You solve this problem? What was it?
    I have similar problem (same fault codes) with my 163PS BDG engine but it only has place when temperature outside is less than -20 celsius.... When engine is warm and I shut it down for ~ 30min and then start again everything is ok.... Maybe it is fuel problem??
    Dec 2011
    Turned out to be the ecu on the fuel pump, I removed it, which is really easy to do and sent it away, I found a company on eBay who repair the ecu for £107, if you search Audi fuel diesel fuel pump edc you'll find the seller.. Cheers
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    all's well that end's well, iv seen there ecu repairs on ebay too, good to hear they do what they say they do,
  1. 2.5TDI 180 white smoke on start up
    By haytch75 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th December 2011, 19:54
  2. Cold start problem and expulsion with smell burning white smoke
    By Variante in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2011, 21:01
  3. Puff (cloud) of white smoke on start up..Is this normal
    By bebecheekymonkey in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th March 2007, 15:29
  4. Cold morning start problems.
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2007, 16:50
  5. audi coupe 2.3 e cold start problems
    By buzby3xx in forum Classic Audi Forum
    Last Post: 27th August 2006, 23:21
