Volks AutosSky Insurance
Results 1 to 16 of 16
    Aug 2009
    191
    2.5 TDI Cold start issues
    Hi i'm getting blue smoke from a cold startup, but clears after 10 seconds, also It can take a while to start when it's cold outside. ie +4deg. When it does start it is very lumpy for a few seconds, like running on 4 cylinders but only for a few seconds?
    Also getting a top end rattle which dissapears when engine has run for a while, although this seems to be getting better.
    Starts fine when the engine is warm! no smoke no rattle fires up on first urn of the starter!
    Any ideas? Engine is a 2.5 tdi AKE with 190,000 miles
    Cheers.
    2002 A4 AVANT 2.5 TDI QUATTRO
    Jul 2007
    770
    Are the glowplugs OK?
    Aug 2009
    191
    how do you check glowplugs? the plug light comes on and goes off, bit slower to go off when cold.
    ta
    Jul 2007
    770
    That sounds normal same as mine 04 2.5Tdi Q but I think you can check the current which gives their glow.Otherwise maybe the coolant temp sensor but that would show on VAGCOM
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Fuel pump timing, and air leaks in the return pipes from each injector are the only other two possibles really.
    Aug 2009
    191
    Well have checked fuel pump timing and it is well in spec.
    Injectors are fine also. Only fault code is for a engine mount.
    So, got some bargain denso glow plugs from ebay £23 delivered for all 6!
    Took ones on left bank out, they were newish ngk and came out easily.
    The ones on the right bank were very old and I had to turn very carefully with lots of wd and loosen/retighten etc.
    Also found that 2 of the leads were loose and not pressed on properly!! Just need a cold morning to test now.
    Will change the oil retention valves under oil filter housing and see if that sorts the occasional tapping. Cams look ok through the fill hole, no grooves but do have wear marks in the surface finish.
    doees the cat have to fully come off to change the retention valves?
    ta
    ADC74's Avatar
    Master Baker
    Jan 2011
    Staffordshire
    148
    Have you got a link to those 'glow plugs' on the bay ?
    £23 sounds well cheap, every set I've looked at have been @ £50 - £60
    Were they 'Denso' or 'Delphi' ?
    ATR vs V6 TDI
    Aug 2009
    191
    delphi,
    GLOW PLUG DELPHI HDS374 AUDI VW SKODA SUPERB 2.5 TDI 3.0 A4 A6 A8 PASSAT T4 | eBay
    offer him £3.50 per plug works out at £23.20 for 6 delivered (only one delivery charge)
    car starts first turn of the engine now, seems to run smoother. One of the old plugs came out in 2 peices so may have been getting a bit of compression loss?
    Mar 2011
    Chester
    167
    Did this solve the smoke too mate?
    A4 (B6) 2.5TDI QUATTRO SPORT AVANT
    Aug 2011
    124
    I run mine on optimax as I thought this would help
    This time round I used normal shell deisel and millers ecomax, it's been better for less smoke on start up but I need run another tank through yet
    Maybe worth a punt for £10 a bottle (treats 10 50l fills) £1 a tank, which I'll probably do once a month, plus it's cheaper to do that over optimax derv
    Aug 2009
    191
    has not smoked on startup since, engine runs so much better from cold.
    I just chuck in asda diesel, £1.36 round here
    Aug 2011
    124
    Got the link to these glow plugs mate?
    Aug 2009
    191
    Quote Originally Posted by DAZ1985 View Post
    look in post no8
    Mar 2008
    Dorset
    13,856
    These are probably made by the very same people who make the oem ones, my only concerns would be they're more prone to snapping when the time comes to take them out
    ADC74's Avatar
    Master Baker
    Jan 2011
    Staffordshire
    148
    Well I've just ordered a set, bit of a bargain for just over £20.
    I've got no evidence in the service history of mine ever being changed so I guess I'll worry about trying to get them out in another 100k.
    ATR vs V6 TDI
    Aug 2009
    191
    I put copper grease on threads before fitting. Just be very carefull removing the old ones
  1. Cold start problem - A3 2.0 TDi 170
    By matt_t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2014, 00:12
  2. 2.0 tdi cold start problem
    By influxsg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st June 2011, 21:53
  3. A6 2.0 tdi cold / not start - engine hesitation
    By JimC64 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th September 2009, 13:56
  4. TDI cold weather issues
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2008, 04:55
  5. Cold start issues? Maybe it;s your O2 sensor.
    By eddyg in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2006, 02:03
