2.5 TDI Cold start issues
neilA4
NULL
Hi i'm getting blue smoke from a cold startup, but clears after 10 seconds, also It can take a while to start when it's cold outside. ie +4deg. When it does start it is very lumpy for a few seconds, like running on 4 cylinders but only for a few seconds?
Also getting a top end rattle which dissapears when engine has run for a while, although this seems to be getting better.
Starts fine when the engine is warm! no smoke no rattle fires up on first urn of the starter!
Any ideas? Engine is a 2.5 tdi AKE with 190,000 miles
Cheers.
how do you check glowplugs? the plug light comes on and goes off, bit slower to go off when cold.
ta
That sounds normal same as mine 04 2.5Tdi Q but I think you can check the current which gives their glow.Otherwise maybe the coolant temp sensor but that would show on VAGCOM
Fuel pump timing, and air leaks in the return pipes from each injector are the only other two possibles really.
Well have checked fuel pump timing and it is well in spec.
Injectors are fine also. Only fault code is for a engine mount.
So, got some bargain denso glow plugs from ebay £23 delivered for all 6!
Took ones on left bank out, they were newish ngk and came out easily.
The ones on the right bank were very old and I had to turn very carefully with lots of wd and loosen/retighten etc.
Also found that 2 of the leads were loose and not pressed on properly!! Just need a cold morning to test now.
Will change the oil retention valves under oil filter housing and see if that sorts the occasional tapping. Cams look ok through the fill hole, no grooves but do have wear marks in the surface finish.
doees the cat have to fully come off to change the retention valves?
ta
Have you got a link to those 'glow plugs' on the bay ?
£23 sounds well cheap, every set I've looked at have been @ £50 - £60 :ermm:
Were they 'Denso' or 'Delphi' ?
I run mine on optimax as I thought this would help
This time round I used normal shell deisel and millers ecomax, it's been better for less smoke on start up but I need run another tank through yet
Maybe worth a punt for £10 a bottle (treats 10 50l fills) £1 a tank, which I'll probably do once a month, plus it's cheaper to do that over optimax derv
has not smoked on startup since, engine runs so much better from cold.
I just chuck in asda diesel, £1.36 round here
These are probably made by the very same people who make the oem ones, my only concerns would be they're more prone to snapping when the time comes to take them out :(
Well I've just ordered a set, bit of a bargain for just over £20.
I've got no evidence in the service history of mine ever being changed so I guess I'll worry about trying to get them out in another 100k.
I put copper grease on threads before fitting. Just be very carefull removing the old ones
