Monster MotorsportVolks Autos
Results 1 to 10 of 10
    sutton coldfield
    440
    Fitting S-line Seats with elec lumber,any advice !?!
    As the title says fitting B7 s-line seats with elec-lumber into B6,,(if I win them) will they just plugg-play ? if not can they be wired-up ? also the seat-belt anchors is it just a straight forward swop they are split rears the same as mine ...Audi A4 2.0 TDI S Line 2007 Complete Interior, Seats, Doorcards, B7 | eBay
    matttrs's Avatar
    Mar 2010
    164
    I bought B7 seats, then sold them again, they dont have a seat belt anchor on. and the loom for the electrics is slightly different, it would be simple splicing job but I sold on and bought the sport leather/alacantra ones instead as they are plug and play.
    the main things like the holes line up etc.
    the rear seats saloon to avant are completely different though.
    Silver A4 wagon on porsche splits
    matttrs's Avatar
    Mar 2010
    164
    cancel that, those ones have a seatbelt on, the ones I bought from an A3 didn't
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Guy's this isn't an A3 forum!
    I've pruned the thread so that maybe Digger can get some sensible advice
    sutton coldfield
    440
    Cheers James...
    27,099
    Yes I'm of the view they can be wired in, but dont do a cowboy job mate, they use a 10amp or so feed & a new fuse point is my advice & is what I do for others for safety reasons, so tapping into an existing may not be wise, my suggestion is to wire them into a proper connector that goes into the existing floor socket, that way easy in/out.
    sutton coldfield
    440
    Thanks,, if I buy the correct connector are you aware if the loom + connector for the B6 Lumber are already there , or is it as you say just a floor-socket in which case is the wiring same colour ?
    27,099
    Without seeing or know your car setup, I couldnt possibly comment fully, but audi wont make there mind up, sometimes they stick wires in place even if systems are used & sometimes they dont & you'd need the correct wires for each part of connector as its not just 1 type or gauge & add wiring as per the rated load for said equipment to be fitted into a fuse point, I dont suggest quick fixes tbh.
    sutton coldfield
    440
    OK thanks anyway, hopefully there be someone along who's done this before...
    27,099
    I have done it before, but not everyone's wiring is identical, hence why I advised you as I did.
  1. Recaro seats audi s3 lumber support
    By sp84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2011, 12:14
  2. S4 or S-Line seats? Need door cards or tan leather seats?
    By sandspeed in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2008, 20:55
  3. S-Line Sportback seats - no S-line embossing
    By funkycat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2005, 19:52
  4. Fitting S3 seats
    By BromleyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2005, 23:18
