    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,579
    bootlid light switch broken?
    The light under the parcel shelf used to come on when I opened the boot.
    It no longer does.
    The bulb is fine, so I'm guessing the switch is gummed up / broken: Where is that switch?
    Ta muchly!!
    LostBok/BahnStormer77
    Oct 2009
    Hull
    1,433
    first thing first
    open the boot and see if it shows on the dash or open it and lock the car if your indicators flash with the boot open its showing as still closed
    mine did the same turned out to be a broken wire where it goes from the main body to the boot across the hinge its either that or the micro switch
    check wires first its free
    BahnStormer
    Feb 2009
    Surrey
    2,579
    simple stuff, well explained!
    car still locks properly with boot open... and there's no boot indicator flashing on the DIS any more (again, with boot open).
    where's the wire / microswitch?
    Oct 2009
    Hull
    1,433
    Open the boot and remove the inside trim on the boot lid remove left trim inside boot look on the left hinge and you will see a plastic cover the wires run inside this you can unclip the wire from the boot and body to give some slack remove the rubber groomet and work the wire through the rubber sleeve till you find the break
    The micro switch is on the catch and needs to be removed to gain access I will put money on the wire though
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,722
    I reckon my wire is dodgy as I get intermittent light failure but always shows open boot on DIS. I'll give this a try too thanks mate!!
  1. brake light switch throwing up ESP light - hard to replace?
    By Rolling Thunder in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th November 2011, 21:59
  2. Help!!! Broken Side Light Connector
    By Pabs in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th January 2011, 19:54
  3. Broken headlamp switch ?
    By Fuzzy felt in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2009, 23:16
  4. Two switch Questions...hazard switch and light switch
    By sleeksx in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2008, 23:59
  5. Broken Foglight switch
    By Clach in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2007, 18:03
