Thread: Fault Codes
    Dec 2011
    Ipswich, Suffolk
    139
    Fault Codes
    Hi Guys & Girls,
    Could anyone tell me what any of these fault codes are and mean and how i can fix them?
    Thanks!
    00526 - Brake Light Switch-F
    36-10 - Open Circuit - Intermittent
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    00956 - Key 2
    35-10 - - - Intermittent
    01333 - Door Control Module; Rear Left (J388)
    80-10 - Single-Wire Operation - Intermittent
    01317 - Control Module in Instrument Cluster (J285)
    49-10 - No Communications - Intermittent
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    sounds like the break light switch has had it, under the steering wheel driver side, you will find the peddles that push on switches.follow the cables,
    35-00 - -
    35-00 - -
    35-00 - -
    35-00 - -
    00956 - Key 2
    caused by the comfort control mudule is stuffed, under the front passenger side carpet foot well,
    maybe your speedo pod is failing
    Dec 2011
    Ipswich, Suffolk
    139
    What does that mean? What will be broken as a result?
    Turkster's Avatar
    Dec 2007
    2,723
    hope my edit helps.
    Dec 2011
    Ipswich, Suffolk
    139
    Sorry i still don't understand ..
    If i leave this faults .. what would happen (worst case)
    What wouldn't work if they fail completely?
  1. fault codes
    By lnewland in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2011, 12:31
  2. Fault codes
    By noddys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2009, 18:26
  3. Fault codes.
    By nickelvery in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2007, 12:37
  4. fault codes
    By a3guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2007, 19:57
  5. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
