Fault Codes
Daniel97
Ipswich, Suffolk
Hi Guys & Girls,
Could anyone tell me what any of these fault codes are and mean and how i can fix them?
Thanks!
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
00956 - Key 2
35-10 - - - Intermittent
01333 - Door Control Module; Rear Left (J388)
80-10 - Single-Wire Operation - Intermittent
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
sounds like the break light switch has had it, under the steering wheel driver side, you will find the peddles that push on switches.follow the cables,
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
caused by the comfort control mudule is stuffed, under the front passenger side carpet foot well,
maybe your speedo pod is failing
Sorry i still don't understand ..
If i leave this faults .. what would happen (worst case)
What wouldn't work if they fail completely?
7
939
B
507
11
693
626
