Chris NottVolks Autos
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By fourcircle
Thread: Electric Seat Height Adjustment.
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    845
    lads, can you tell me if non-recaros lift separately front and back (like the rearos do)? my manual sports seats lifted by pumping the handle up or down. then the front (under the thighs) could be lifted up and down by a separate handle. with the recaros there is a switch on the side and you can move the front or back of that switch to raise and lower the front or back of the seat base.
    I have a problem with the rear lift mechanism so I need to know if the motor from a non-recaro would work in my recaro base
    cheers
    Anybody selling a polisher? PM me.
    A4 B6 3.0 Quattro Sport Avant
    LandSpeed's Avatar
    Nov 2006
    Birmingham
    226
    i have electric seats and yes i can raise and lower the front of the seat base indipendently to the back portion of the seat base.
    Hope this helps fourcircle
    1.8t Multitronic 2002
    RNS-E - Xenons - Full Leather - Cruise - DIS - Interior Light Pack - Ambient Lighting - RS4 ARB - 19" Hartman MTM Reps
    Ready to be installed: S Line front spoiler - S4 Rear Bumper - Eibach Sportline Springs
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    845
    Yes, that's great mate. Hopefully it's a similar set up with the motors then.
    Z82
    Apr 2006
    Inverness, Scotland.
    453
    Any joy? Mine's buggered too
    7. 2003 B6 Nogaro Blue S4 v8 quattro
    Gone but not forgotten:
    6. 1996 B5 Casablanca White A4 2.6 v6 quattro Sport
    5. 1989 B3 Maroon Coupe 2.0E
    4. 1986 B2 Red Coupe 2.2E Limited Edition
    3. 1985 B2 Red 80 Sport
    2. 1983 B2 Black 80 Sport
    1. 1984 B2 Silver 80 Sport
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    845
    i've gone for my favourite approach.. if nobody has an answer.. have a go and see! I just bought the seat base and motor so will know when it arrives and I get time to have a go at fixing it. That may not be this side of xmas but I'll let you know how I get on. This is what I bought by the way eBay - The UK's Online Marketplace
    Z82
    Apr 2006
    453
    I'll no be fixing mine for a while as I manually lowered it for now. 330 seems a bargain, let me know how you get on.
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    845
    How did you manually lower it? I could do with raising mine a little bit as it's currently at its lowest
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    845
    right... so the good news is it's possible to fix this problem.
    It's not the motor but the "gearbox" mechanism that it's attched to. well.. in my case anyway. I bought this eBay - The UK's Online Marketplace although I should point out that ETKA lits the seat base as without motor. whether the part bought from the dealer will have the gearbox bit I don't know. I'll double check the old part in case there's a separate part number on it but I don't think so. seat base is part number 8E0 881 158.
    I removed my seat and laid it on its back in my garage to get access from below. I could have taken the 24mm nut and two torx head bolts out in that position but the inner side of the 24mm nut is a thick torx headed bolt and there isn't enough room to slide it out unless your seat has broken while at its highest.
    If it's just your motor that's broken then you can detach it from the gearbox by undoing the two very small trox headed bolts you can see by looking down the length of the motor. To get the motor out from the seat base you can unclip the electric connectors just inside the plastic trim (behind teh switches). that will give you enough space to slide it out and the new one in again. remember to unclip the electrical connector by cutting away the tape and then push the connectortowards the back of the seat.
    So anyway, to get proper access I had to undo two torx bolts holding the horizontal bar that has a motor mounted on it for operating the forward and back movement of the seat along the runners. I also had to undo the large bolt that forms the pivot for the front part of the up and down lift mechanism. see these pictures for what I mean
    the runner at that side can now be gently pulled away a bit, which will bring the gearbox part away from the underside of the seat so you can slide the thick bolt out. This will leave you free to lift out the gearbox and the metal plate it's attached to. When i did this I accidentally unclipped the rod that operates the forward-backwards runner but it clips back again into the motor at one end and the mechanism at the other end.
    Get the new gearbox thingy in place, put the thick bolt back through and tighten on the 24mm nut at the other side. Now get the three bolts back in again that allowed you to drop the runner down. that took me a bit of jiggling to get things lined up.
    It may be possible to put all this back in place with the new motor still attached to the gearbox but I had the motor off already so I did this and then slid the new motor in, inserted the two small torx bolts holding it onto the gearbox and put the electrical connector back in place.
    It's worth mentioning that if/when you disconnect the motor from the gearbox there's a piece that fits into the geabox in the form of a metal "screw" (the thread of the screw turns against the teeth of the mechanism to create the movement). The other end is a flexible bar that inserts into the motor. I removed mine while working out what went wrong with the old one and realised that the end of the screw needs to be engaged in the mech before the motor is attched. if you take it out then make sure to put it back in, turn by hand clockwise until the screw appears to be physically moving down into the gearbox and adjust back and forward until the plastic edge is flush to the end. that will make sense if you find yourself doing this. otherwise.. probably not. the screw wouldn't catch in the broken gearbox, suggesting to me that the problem lies within it.
    new gearbox and motor connected, seat back into car and Robert's your mother's sibling... all should be well again. It was for me.
    Deanlad likes this.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,695
    Nice one mate, I've editied the thread title to help future searches.
  1. Electric Seats
    By Acidic32 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2009, 19:38
  2. non electric seats?
    By emery1990 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2009, 19:29
  3. electric seats
    By olds_kool in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th January 2009, 10:37
  4. Electric seats
    By dan.obi in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2007, 21:21
  5. Retrofit Electric Seats - Can it be done?
    By A44NI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th April 2007, 22:14
