EM TuningAH Fabrications
Results 1 to 8 of 8
    Aug 2011
    124
    Pre cat and cat/dpf removal 2.5tdi
    I know it's been covered many times before but just want to clear up a few questions?
    Is it just a case of removing the innards and refit?
    Will it show any error on vagcom once removed?
    Was thinking of welding in a few pipes to join them up rather than just knock the inside of them out, then their always their if ever needed one day?
    Dec 2010
    Huddersfield
    30
    I have been told that it is best to have new pipework fitted but keep the sensors in place on the new pipework. I'm going to have this done before xmas on my 2.5tdi.
    Aug 2011
    124
    It'll be a few weeks till I'm on the right shift to do it. The pre cat looks like the hardest bit to do.
    If you could post feedback when you've done yours regards the pre cat side of it that would be good
    Dec 2010
    Huddersfield
    30
    Yeah I will do buddy. Im deciding whether to get a whole Stainless Steel system built or just replace the 3 cats!
    Aug 2011
    124
    No gains in the stainless over standard I wouldnt have thought
    I'm thinking the cheaper option is best for me and maybe have tips put on the standard boxes at the rear
    Jul 2007
    London
    3,074
    Just take the darn things off and knok the innards with a rod trough, they are passive on the v6 tdi engines so wont bring any emission lights on dash ! It will help with spooling the laggy garrett turbo sooner which you will love and if you remove the back box it will make such a nice noise you'll wont believe it's a diesel !
    FOR SALE:
    Dec 2010
    Huddersfield
    30
    Taking them off and knocking out is not within my skill set and prefer just to remove the existing pipes completely in my case. The noise would be good I guess but not really something I want in my day to day vehicle, it gets annoying after a while. Each to their own!
    Aug 2011
    124
    So basically one middle box, no back boxes and the 3 cats removed?
    Is that what video on YouTube has got done on the b5? If you know the link I mean?
  1. Pre Cat Oxygen Sensor - Where to Buy?
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2011, 09:45
  2. will 2005 s3 2.0 downpipe and cat fit pre facelift
    By garyrmills in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2009, 15:40
  3. Where to get a Pre Cat Lambda Sensor from for best price? BAM Engine
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2009, 22:43
  4. pre cat lambda sensor?
    By Slick S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2008, 14:20
  5. Pre-cat?
    By mattpanton in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th July 2007, 11:41
