EM TuningAH Fabrications
    Lancaster
    1,787
    Swapping the brakes over this weekend. Any advice
    Done most things on a car from the basics to engine conversions and gearbox conversions. So all is good.
    Any advice though? Finally upgraded to a Eezibleed kit for ease of the task and to stop any flipped seals. Also invested in a hose clamp.
    I'm going over from the standard 312mm to the S4 345mm setup.
    I have everything from the S4 including the hubs. I assume the calipers and hangers bolt onto the A4 hubs to save swapping the whole lot.
    If I read correctly I bleed closest to the master cylinder first. Got some Dot 4 but the higher grade stuff. Not a fan of 5.1.
    Anything I've missed?
    To do: None yet.
    Oct 2009
    Hull
    1,442
    bleed furthest away from the cylinder first :-) and your supposed to cycle the ABS pump too
    Jan 2011
    612
    Lots of WD40, a good blowtorch and the right sized Allen keys........ I did pads and discs all round earlier this year and this was the biggest problem.....
    03MY 52 reg 1.9 TDi 130PS Quattro Sport Avant - 170bhp remap, RNS-E+OEM bluetooth, B7 wiper arms/blades, 4300K HID+nightbreakers/LED sidelights, rear tints, new lights all round, new front/rear screens, frt armrest, s-line kit, cruise/DIS, B7 gearknob/aluminium trims, parking sensors, black grilles, RS4 RARB, S4 front end, black 18" RS6 alloys
    Still waiting..... S4 rear bumper, exhaust tips, coilovers, leather recaro's.... phew...
    Lancaster
    1,787
    The discs and pads on it at the moment aren't too old. So all is good for being siezed.
    I read that it's closest first when pressure bleeding. Is there an option in Vagcom to cycle the abs?
    To do: None yet.
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    also make sure you have plenty of brake fluid, at least 2 litres
    Lancaster
    1,787
    Got the brakes swapped over today. Only used a litre, I clamped the hoses before taking off the old ones. So alot less fluid lost and drained. All the air got out using a Eezibleed kit.
    Feels alot better. I've been out and tested the brakes, holy mother of god. The initial braking isn't much different from standard. But when you really plant the brakes down it stops you hard. So i've mad the abs working hard tonight. I'm going to give them one last quick bleed tomorrow. Anyone know how to do the clutch?
    To do: None yet.
  1. Needing some better brakes advice please?
    By Hendo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st September 2011, 22:01
  2. Squeaking Brakes - Help and advice please......
    By CHRIS555 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th December 2010, 21:12
  3. a4 1.8t ecu swapping advice
    By yanspeed in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th June 2010, 18:22
  4. Replies: 2
    Last Post: 1st September 2008, 19:35
  5. porsche brakes advice
    By Ballcrusher in forum Handling
    Last Post: 2nd January 2007, 10:27
