EM TuningAH Fabrications
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By olly quattro
Thread: Too rich and too lean! Ahhhhh
    bowen's Avatar
    Mar 2011
    456
    Hi guys,
    Recently had some running problems with my a4 b6 cab, BFB engine code. I was getting 3 codes; running rich,running lean and high rpm at idle. With a bit of research it led me to the crankcase breather valve. I replaced this and a good job I did as the old one was shafted. Now I have replace it with a genuine part I have just got CEL 17545 and 17536 running rich and lean?! How!? It had a new maf around a month ago.
    Any help would be great, thanks.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    would a lambda sensor cause your faults bowen ... just a guess !!!!
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    bowen's Avatar
    Mar 2011
    456
    I've looked at Ross tech, it does suggest lambda sensor, maf or vac/boost leak? Im getting it smoke tested next week, that should eliminate the leak, hopefully.
    Sep 2010
    167
    I would be looking at all the rubber hoses around the throttle valve carefully for any splits, deterioration, holes etc..... Especially between the air mass meter and the throttle valve. An air leak could cause a high idle and mixture trim faults.
    bowen's Avatar
    Mar 2011
    456
    i hope the smoke test shows up an air leak!
    will let you know.
    bowen's Avatar
    Mar 2011
    456
    Does any one have an etka for the diverter valve location?
    Sep 2011
    75
    diverter valve is down the bottom of the engine bay accessed from under the car, Number 14
    bowen likes this.
    bowen's Avatar
    Mar 2011
    456
    found it, cheers mate!
    bowen's Avatar
    Mar 2011
    456
    Ok, so i had no leaks from the smoke test. I still get 17545 and 17536.
    Also to note, my temp gauge works intermittently? would this cause these codes, it has had a new temp sensor last mont though?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    What *exactly* does the Ross-Tech wiki list those codes as?
    bowen's Avatar
    Mar 2011
    456
    17545/P1137/004407 - Fuel Trim: Bank 1 (Add): System too Rich
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    Possible Causes
    • Mass Air Flow (MAF) Sensor faulty
    • Fuel Pressure Regulator faulty
    • Fuel Injector(s) faulty
    • Oxygen Sensor Control faulty
      • Oxygen Sensor(s) faulty
    • Evaporative Emission (EVAP) System faulty
    Possible Solutions
    • Check Mass Air Flow (MAF) Sensor
    • Check Fuel Pressure Regulator
    • Check Fuel Injector(s)
    • Check Oxygen Sensor Control
      • Check Oxygen Sensor(s)
    • Check Evaporative Emission (EVAP) System
    bowen's Avatar
    Mar 2011
    456
    17536/P1128/004392 - Fuel Trim; Bank 1 (Mult): System too Lean
    Possible Symptoms
    Possible Causes
    Possible Solutions
    bowen's Avatar
    Mar 2011
    456
    My next point of call is Lambda sensor/s
    Sep 2012
    10
    Hi! I have almost the same problem
    My car is a A4 2.0 liter engine, ALT sedan 2001
    There is two recurring error in Engine. I also linked what suggest ross-tech wiki
    16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
    Possible Causes
    • Leakage in Intake and/or Exhaust System
    • Catalyst faulty
    • Oxygen Sensor(s) Control faulty
    Possible Solutions
    • Check Intake and Exhaust System for Leaks
    • Check Catalyst
    • Check Oxygen Sensor(s) Control
      • Perform Oxygen Sensor(s) Aging Check
    17544/P1136/004406 - Fuel Trim: Bank 1 (Add): System too Lean
    Possible Solutions
    • Check Fuel Pump
    • Check Intake/Exhaust System for Leaks
    • Check Secondary Air Injection for Leaks
    • Check Vacuum Lines for Leaks
    I have checked both O2 (lambda) sensor's heater resistance.
    Attachment 10383Attachment 10384
    G130 (4 pin connector) lambda probe's resistance between 2 and 1 pin was 8 Ohm around ~ 5°C I think this is OK
    G39 (6 pin connector) lambda probe's resistance between 4 and 3 pin was 2,7 Ohm around ~ 5°C Is this resitance OK?
    G39 had a cap, I took off and take measured. I find it is the 6 and 2 pin was 107,9 Ohm around ~ 5°C
    Attachment 10387
    Measuring Block 006 field 4 Lambda was -3,1%
    Last week was -4,7%
    Attachment 10386
    I also find a manual. O2_Sensor_Testng_DIY V2.pdf
    Attachment 10380
    In field 2 I had a readout of ~1,5 V, wich is out of spec 0 V - 1 V. What is wrong?
    Attachment 10381
    Attachment 10382
    That's it until now.
    Any thoughts?
  1. Rich under load, lean at idle ?
    By ben4866 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2009, 09:07
  2. Alloys - A6 Avant 1999 oh no/yes ahhhhh!
    By Audime in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th July 2009, 18:35
  3. Airbag Light ahhhhh
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2008, 17:21
  4. RATTLES...ahhhhh
    By terrysingh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th June 2007, 18:48
  5. Running Rich or Lean???
    By Rallyman in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th February 2006, 08:34
