Chris NottMonster Motorsport
Results 1 to 8 of 8
    Sep 2011
    30
    best spark plugs for 2.0 fsi...
    What are the best spark plugs for the 2.0 fsi engine? I know fsi engines are fussy on the manufacturer/model of spark plugs they have, so can anyone give me any advice? thanks
    Sep 2011
    30
    Anyone?
    Sep 2010
    167
    Best plugs imho are o.e std plugs. They were chosen by audi to be the best suited plug for your engine. Bosch or ngk are most known types. Are you looking to upgrade them? The only obes ive used are denso iridium, expensive but seemed to be a good plug.
    Sep 2011
    30
    The ones i've got in at the moment look a bit worn, so I was just wondering if there is any upgrades, and Ihave a miss fire at low rpm, and wondered if the spark plugs could be causing this.
    Aug 2011
    124
    Not a great believer in upgraded plugs meself
    Standard plugs more than upto the job
    Mar 2012
    45
    Anyone able to tell me what the standard plugs are for this engine???
    Thanks!
    warren_S3's Avatar
    Oct 2007
    6,093
    I've always found NGK's to offer most consistent result. As it's in the B6 forum and the first car mentioned is a 2.0FSi, I'm 'assuming' your car is a 130bhp model and manufactured some time between 2000-2005. If not then these part numbers are not right.
    OEM Part: BKUR5ET
    Iridium Part: BKR5EIX
    Iridium tipped plugs have harder tips, so in motorsport applications they last longer. I used them for about 4 years with mixed results, and have returned to the standard platinum electrode plugs as they seem to foul less in the FSi engines, especially when modified. Also NGK say they conduct better than the Iridiums which as built for endurance rather than outright smooth running.
    If these aren't the right ones, suggest you look at this website that helps you choose step by step: NGK Partfinder Catalogues
    Mar 2012
    45
    Mines actually a 2.0FSi AXW A3 150bhp
    Cheers for the info! I'll check out the link mate
  1. Spark Plugs
    By S3 TAM in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2011, 14:26
  2. 3.0 V6 SPARK PLUGS
    By dans3.0 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2009, 15:38
  3. Spark Plugs
    By S3fan in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2009, 23:05
  4. Desno IK20 Spark Plugs - Should I Change the Spark Gap?
    By MarkyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2007, 17:14
  5. Which spark plugs?
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2005, 16:50
