Chris NottAH Fabrications
Results 1 to 7 of 7
    Nov 2011
    Help with 2.0 fsi
    Hi,
    I am having really trouble with my wife's A4 2.0 fsi avant.
    The car has really rough idle and fuel consumption is poor, the car has had new plugs and coils and has also had new ox sensor, the car runs fine but idles like it is going to stall
    Nick
    beachbuggy's Avatar
    Surrey
    1,727
    Air leak or faulty maf are the likely problems. I know everyone likes to say get it scan on vagcom but in this case I think it's a good idea. I would tend to go with an air leak though.
    sutton coldfield
    440
    would agree with b-buggy, I've got the same engine and a while back had the same symptons,, turned out to be a breather hose that goes from rocker cover into the plastic inlet manifold to the right of the engine .
    Nov 2011
    Thanks for the reply, I have read the codes and there are 5!!!!!! Struggling to find real info on them though
    Funny enough I disconnected the maf earlier and the idle smoothed out, but I am also getting a rich smell
    Nick
    Nov 2011
    Quote Originally Posted by Digger1 View Post
    Mmmmm I may have to check them tomorrow
    Nick
    beachbuggy's Avatar
    Surrey
    1,727
    http://www.airbagnews.com/PDF/Fehler...%20english.pdf
    Try here for fault codes or post up.
    Nov 2011
    I had the codes read on vag com and they are as listed:
    17414 - torque diff cylinder 3 p1006 - 001
    16698 - misfire detected single cylinder p0314 - 001
    17947 - clutch pedal switch p1539 - 004
    17560 - long term fuel trim addivtive air p1152 - 001
    16684 - random/multiple cyclinder misfire p0300 - 008
    16688 - cylinder 4 misfire p0304 - 008
    Nick
  1. A3 1.6 / 1.6 fsi
    By johnsnow in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2010, 11:04
  2. a3 1.8t fsi help
    By PeteWest in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2008, 12:27
  3. FSi S4
    By dbm in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th October 2005, 22:45
  4. A3 3.2 to 3.2 FSi?
    By nicks3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2005, 17:51
