Chris NottVolks Autos
    Jan 2011
    Hemel Hempstead
    12
    Still overboosting!!!!
    A4 2.5tdi, still overboosting, changed boost switch on intercooler, boost vacuum sensor, vacuum pump, replaced all vacuum pipes with silicone items, removed turbo and cleaned(all vane operations working correctly), only thing not replaced so far is actuator.
    Initial boost under load goes over 30psi, then dumps a load and settles at approx 18psi, which is still probably high.
    Any ideas what standard boost level should run at?
    And any ideas what could be causing it.......
    Although i must admit its quite a nice boost when it comes in
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    id aim a guess of around 8-12psi standard m8 but as stated purely a guess
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    Actuator may be playing up then mate, or the sucker that feeds it, try taking the pipe off the actuator and see if there is any difference.
    I once had over boosting due to a slight split in one of the pipes that went to the inter cooler on the passengers side, you could only see the split with the system was being pushed and the pipes was all expanded,
  1. Remap, overboosting now
    By Marc1 in forum Awesome GTI
    Last Post: 25th July 2009, 09:36
  2. A3 overboosting
    By keets in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2007, 15:10
  3. Overboosting?
    By k17rpo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2007, 23:15
  4. Overboosting? Help!
    By marctwo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2006, 12:54
  5. overboosting?
    By jimboA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2004, 13:19
